Arduino and 1.4Amp/Phase Stepper Motor
I am brand new to the Arduino (I just bought my first!) and looking for a little guidance. I am looking to control a stepper motor whose power requirements exceed what is managable with a standard stepper card (EasyStepper V3 or a shield card). The motor I am looking to control has a 1.4Amp/Phase requirement. I was planning to purchase a microstep driver and use the arduino to provide hi/low for direction and the pulses for the step clock.
I will be using a Xport Direct+ and sending commands to the arduino from a computer on the network. I intend to program the arduino to translate the commands received over the Xport into a series of pulses sent out to the stepper driver to produce the approriate number of steps.
Does this sound like a reasonable process? I'm not too concerned about the nitty-gritty of the coding yet, I just want to make sure that the overall method seems like to could work.
Thanks
Any suggestions? Does this seem reasonable?
As long as the microstep driver can handle the current pr. phase you require it sounds like its possible.
I don't know the microstep thingie, but if it has inputs that can be controlled from Arduino ( like 0 V / 5 V for high / low) you should be OK
I am confident that the driver is capable of handling the motor. I am more concerned to confirm that the arduino is able to produce the pulses (hi/lows) for the driver.
Are you sure something like the easydriver won't work? The reason I say this is that the amperage required is the amp required at a specific voltage. With a chopping driver, like the easydriver, it runs it at a much higher voltage, measuring the feedback from the motor - and drives it as high as it will go w/o damaging the motor before quickly turning it off.
If you run it at least 2x the rated voltage, then you should have no problem - you'll be able to take advantage of the chopping driver in the ED.
I have some 6V ~1A (not sure of exact rating) steppers that run very poorly at the max 750mA current @ 6V on the ED, but when running at 12V, I actually tune it down to about 400mA and they work great.
Here's a little more info on chopping/current limiting:
http://www.stepperworld.com/Tutorials/pgCurrentControl.htm
!c
I've looked at the easystepper and I don't believe it can handle the motor. The motor is set for 24VDC, 1.12Amps/Phase. I also have a second motor I plan to use the same system to control which has even higher requirements. I believe that using an external driver deals with this, and I can use to Arduino solely as a controller.
Ultimately I am trying to avoid purchasing a massively expensive controller capable of receiving commands via ethernet. This things run $1500 and up. An Arduino with an ethernet shield may be able to all I would be using the fancy controller for.
Yep that's no problem for the Arduino.
