Arduino and ALED1262ZT via I2C
Helo
Is there any dedicated Arduino library which handle the ALED1262ZT over I2C? or what libraries can i use to connect each other via I2C to drive leds ?
Best Regards
They way to answer any such question is to Google for "ALED1262ZT Arduino Library". I tried that but did not see one. I guess the answer is no.
You can use the built-in "Wire" library. Communicating with the chip using the Wire library will require careful reading of the data sheet to understand the chip's internal registers and it's operation.
https://www.st.com/resource/en/datasheet/aled1262zt.pdf
As a beginner, it might be best to choose a similar chip for which there is a dedicated Arduino library. What is your project?
