I have a problem, lack of flash memory. I can not use "Mega" the 2560, my project has to be DIP socket.
The processor ATMEGA644 is compatible? What needs to change to be compatible?
http://www.farnell.com/datasheets/82623.pdf
Advantages:
DIP Easy to assemble, we can use sockets. 40-pin PDIP, 44-lead TQFP, and 44-pad QFN/MLF 32 Programmable I/O Lines 64K Bytes of In-System Self-programmable Flash program memory.
Features • High-performance, Low-power AVR® 8-bit Microcontroller • Advanced RISC Architecture – 131 Powerful Instructions – Most Single-clock Cycle Execution – 32 x 8 General Purpose Working Registers – Fully Static Operation – Up to 20 MIPS Throughput at 20 MHz • High Endurance Non-volatile Memory segments – 64K Bytes of In-System Self-programmable Flash program memory – 2K Bytes EEPROM – 4K Bytes Internal SRAM – Write/Erase cyles: 10,000 Flash/100,000 EEPROM(1)(3) – Data retention: 20 years at 85°C/100 years at 25°C(2)(3) – Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation – Programming Lock for Software Security • JTAG (IEEE std. 1149.1 Compliant) Interface – Boundary-scan Capabilities According to the JTAG Standard – Extensive On-chip Debug Support – Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface • Peripheral Features – Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes – One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode – Real Time Counter with Separate Oscillator – Six PWM Channels – 8-channel, 10-bit ADC Differential mode with selectable gain at 1x, 10x or 200x – Byte-oriented Two-wire Serial Interface – One Programmable Serial USART – Master/Slave SPI Serial Interface – Programmable Watchdog Timer with Separate On-chip Oscillator – On-chip Analog Comparator – Interrupt and Wake-up on Pin Change • Special Microcontroller Features – Power-on Reset and Programmable Brown-out Detection – Internal Calibrated RC Oscillator – External and Internal Interrupt Sources – Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby and Extended Standby • I/O and Packages – 32 Programmable I/O Lines – 40-pin PDIP, 44-lead TQFP, and 44-pad QFN/MLF • Speed Grades – ATmega644V: 0 - 4MHz @ 1.8 - 5.5V, 0 - 10MHz @ 2.7 - 5.5V – ATmega644: 0 - 10MHz @ 2.7 - 5.5V, 0 - 20MHz @ 4.5 - 5.5V • Power Consumption at 1 MHz, 3V, 25°C – Active: 240 ?A @ 1.8V, 1MHz – Power-down Mode: 0.1 ?A @ 1.8V
