Arduino and Blender
hi everybody, i'm trying to communicate the arduino with blender, but i have a lot of problems..
This is the arduino code, the arduino take the value of a potentiometer and send de data when receives an 'a'
int potPin = 0;
int val = 0;
if ( Serial.available()) {
char ch = Serial.read();
if ('a'==ch) {
val = analogRead(potPin)/4;
Serial.print(val);
this is the phyton code in blender
import serial
serialport = serial.Serial('COM5', 9600)
for i in range(1, 100):
serialport.write('a')
x = serialport.read(size=1)
y = ord(x)
print "y=", y
else:
serialport.close()
doesn't work, what do you recomend?--- what i'm doing wrong?
Try this (Arduino side)...
[glow]byte[/glow] val = 0;
srry,, doesn't work
when i test it in "serial monitor" of arduino,, when i put an 'a' the serial gives me the data ...
i think the problem is in phyton
in the arduino code instead of serial.print() use serial.write()
I don't see anything wrong with your python code.
also it's probably the copy paste but the x = serialport.read(size=1) is not aligned with the rest of the code in the for loop. the code won't run if the code isn't indented right.
srry, doesn't work
when i run the python script the program gets stuck, it seems that the program doesn't send anything to the port
I think I noticed a mistake.I think the else can't be used without an if statement so instead of using the for loop try this:
i = 0
while(1):
if i < 100:
serial.write('a')
etc...
else:
serial.close()
break
i++
In your Arduino code I think there is a mistake in the header of your if statement:
   if ('a'==ch) {
       Serial.print(val);
if 'a' == ch
should be
if ch == 'a'
Adrenalina is right, Else only works with If. Just take the Else out and the serial.close() will automatically execute when the for loop is finished. I think that's what you're trying to do:
y = ord(x)
print "y=", y
serialport.close()
Looks like a cool project.
if 'a' == ch
should be
if ch == 'a'
Makes no difference which order the operands appear in. They are being tested for equality.
hi everybody, finally i could communicate the arduino with the blender game engine.
i get the information from here:
http://en.myinventions.pl/index.php?page=ArduinoToBlender
i'm controlling a cube with 2 potentiometers (2 externals signs) one is for the direccion and the other one is for the speed, as you can see this ambient, cube(blue) , floor (green), ramp(gray)
Arduino code
Serial.print(analogRead(0)/4, BYTE);   //direction
Serial.print(analogRead(1)/4, BYTE);    // speed
delay(40);
this is the python script which receives the 2 inputs from the serial port and write them on the text file.
import serial
serialport = serial.Serial('COM3', 9600)
while 1:
    dane=open('dane.txt', 'r+b')
    print x
    dane.write(x)
    y = serialport.read(size=1)
    print y
    dane.write(y)
    dane.close()
serialport.close()
this is the python script of the blender game engine which controls the direction and the speed of the cube.
import GameLogic
dane=open('dane.txt', 'rb')
x=dane.read(1)
y=dane.read(1)
dane.close()
contr = GameLogic.getCurrentController()
location=contr.actuators["loc"]
z = 0.001*(ord(x)-128)
location.dRot=[0,0,z]          // direction
w = 0.001*(ord(y))
location.dLoc=[w,0,0]     // speed
contr.activate(location)
i need to send a character to the serial port when the cube is climbing the ramp
i already have the code that identifies when the cube is going up with a variable, the variable is "a" and when the cube is going up a==1 and a==0 when not.
the reason that the first code doesn't have end is because i need to communicate the 2 external signs at every moment, and both scripts are running at the same time.
the second code is where i have the variable and in the first code is where i get the data from the serial port, so i dunno how to communicate the 2 scripts.
i would like to say if the variable a==1 send a carachter but as in this one i haven't the serial communication i dunno how to do it
