You don’t need any latches to do what you want, all you need is software. This is almost the same software as you will need to drive a latch, so there is no need for a latch.
i know i can do that with software my project board is a due and i just have 13 pin availaible and i would like to drive more than 15 leds so thats why
the idea is not to put only one latch , it is the put 2 or 3 74hc so that couldnt be do only by software
Then in that case you don’t want a D-type latch, there is no pin advantage in that. What you need is an addressable latch like a 74HCT259, or a port expander like a MCP28017.
Then why does it say Mega 328 on your diagram? That is just what is in the Uno.
You can do all this without an Arduino by using a LM3914, LM3915 or LM3916. They make a voltage input and light up the number of bars according. Each one has a different relationship between the voltage and what bars are lit up, like linear, dBs or log.
I probably badly explain what i want to do , im french ;D
the idea is to use the atmega328 but if i can i will use it on my due ,
the problème is i dont have enouth available pins on my due because it is on a big project
i read the data sheet of the two componant you say and first it's not exactly what i want to do, and they are not disponible on the website where i will buy xD
the global objective is to make something able to memorise state on a pins when an impulse go in , (a D latcch xD)
because at the end there will be 2 or 3 structure like that .
so the only thing i don't know is , the D latch will work for that .
thank for your help in any case ^^
No it is not, your object is to light LEDs according to some software criteria.
Forget impulses they are just a distraction about the details of how to achieve what you want to do.
This is called an [url= http://xyproblem.info/]X-Y Problem[/url], it is not the problem you have but a problem with how you think you are going to achieve a solution.
Yes those chips will solve your problem.
You don’t seem to be understanding what those chips will do, they will give you more pins. A D-type latch will not give you more pins because it takes you more pins to drive than you would need to just use a single pin.
Your mind set seems to be fixed on impulses, it is irrelevant.
disponible - in English is disposable - which means things you can throw away. I suspect you mean "for sale".
How about buying at a place that has a decent selection of chips?
So I will leave it up to others to suggest other things you will not like.
Why ask a question if you are going to reject answers that for some uncountable reason you don't like?
as i say i'm french xD
i havn't any problème with your solution , i just want to buy all of it on the same website. i will search if i can't find a good website withound 100E or deliverie xD
Is this a secret web site because if you don’t tell us where it is how on earth can we guess what it sells? My crystal ball is on the blink here so I only know what you tell me.
So how about you start by giving me the url of "no gotronic" and telling me what you want to buy apart from port expander chips?
It is unlikely that one website will have the best prices on everything.
I thing you don't understand the idea
All the latch will be on the same pins
But the pin control will be on one pins each so
I juste have to select the latch and write on it
