Arduino and Daisy MP3 Player
Hello everyone. I'm working with the Arduino board and the Daisy MP3 Player (purchased through Make Mag - info avialable here:http://www.teuthis.com/html/daisy_mp3.html )
The code below is written for the Four-Four Mode and does play track 0001, however it only plays it for about one second.
According to the Daisy manual the B0 pin on the Daisy "is used to strobe in the track section." Later it says "momentarily bring B0/INTO low. I think this is where the problem lies in the code below. I couldn't get track 0001 to play at all when I just set B0 to LOW, that's why this code also sets the b0 to HIGH. When it is set to high it plays the correct track but only for a moment. I want it to play the track for the whole duration of the track.
Since I wrote the info above, I've tried a few other approaches. It seems that I am unable to get a "Low" or ground signal out of the arduino.
Thanks for any help you can offer. Cheers! JLK
//* PLAY Composition 00001
//*code by Jenn Karson
int Pin10 = 10; //arduino pin 10 goes to Daisy MP3 pin 0
int Pin9 = 9; //arduino pin 9 goes to Daisy MP3 pin 1
int Pin8 = 8; //arduino pin 8 goes to Daisy MP3 pin 2
int Pin7 = 7; //arduino pin 7 goes to Daisy MP3 pin 3
int Play11 = 11; //arduino pin 11 goes to Daisy MP3 B0
void setup() //run once, when the sketch starts
pinMode (Pin10, OUTPUT);
pinMode (Pin9, OUTPUT);
pinMode (Pin8, OUTPUT);
pinMode (Pin7, OUTPUT);
pinMode (Play11, OUTPUT);
void loop() //run over and over again
{ // Play track 0001
digitalWrite(Pin10, HIGH); // Dailsy MP3 Binary Track Choices
digitalWrite(Pin9, LOW);
digitalWrite(Pin8, LOW);
digitalWrite(Pin7, LOW);
digitalWrite (Play11, LOW);
digitalWrite (Play11, HIGH);
It looks like your code is most likely doing what you want it to do. It's probably just a grounding problem. Make sure the Arduino and the Daisy share a common ground, otherwise, 0V on the Arduino could mean any value when interpreted by the Daisy.
Thanks for the reply!
I just did an experiment based on your suggestion - and got it to work! There is only one obvious ground on the daisy mp3 and it is the same one that connects to the ground connection of its battery pack. My question is this: is it OK to have a wire from the arduino connected to the same pin that also connects to the Daisy battery pack?
Thanks,
JLK
Connecting grounds should be safe, although I don't quite understand how you are describing it. You can run a wire from the main Arduino ground to the main ground of the Daisy player which will effectively ground the extra battery pack to the ground of the power source you are using for your Arduino, which I'm assuming is USB? If the unit goes portable you could just as easily use the same battery for both the Daisy player and the Arduino and you accomplish the same thing.
If you're worrying about connecting wires (I'm always worried about that), the grounds are just floating voltage references you shouldn't have to worry about any current passing through the wiring or damaging any of your components.
Great. Thank you!
