Arduino and Delphi - Serial communication problems ?
Hi everybody!
Sorry for my English, I’m French…
I am trying to make a communication with Delphi and Arduino exactly like this stuff : http://www.thepenguincult.com/proyectos/arduino-delphi-lm35/
The future objective is to read the value of a sensor and visualize it with a program made with delphi using GLScene (experiment of visuals).
I made it simple to try it, you will have only to connect the arduino to the PC, without have to connect any component to the arduino.
The objective is to send a variable to the PC with the SERIAL/USB default interface included to the arduino.
Here, I made this program :
int numero;
  numero=0;
  Serial.println(numero);
  delay(100);
  numero=numero++;
We send to the serial port each 100 millisecond a number which will increase.
I found this application of a serial terminal (You have to put your arduino into COM1 or COM2) and I added a line to recuperate the variable sent by the arduino into the caption of the form.
I have a result totally crasy, it’s look like the program recieve varios packages… without the final “enter” del printLN…
I need to have 1 and 2 and 3 etc … but not 12345 and 67891011 and 1213141516 … into my form caption…
I need these variables separated correctly.
You will need to add the dclsockets package to the IDE.
To do this go to Component | Install Packages | Add (/bin/dclsockets70.bpl).
Here you can download this program delphi : http://www.megaupload.com/?d=TVOCY22U
Now, I’ve tried to make it with an other type of Arduino Program :
int pin = 0; // analog pin
int tempc = 0,tempf=0; // temperature variables
int samples[8]; // variables to make a better precision
int i;
int n;
  Serial.begin(9600); // start serial communication
for(i = 0;i<=7;i++){ // gets 8 samples of temperature
 // samples[i] = ( 5.0 * analogRead(pin) * 100.0) / 1024.0;
 // tempc = tempc + samples[i];
  delay(250);
tempc = tempc/8.0; // better precision
n = n + 1;
Serial.print(n,DEC);
tempc = 0;
delay(250); // delay before loop
This program is a modified version of this project : http://www.thepenguincult.com/proyectos/arduino-delphi-lm35/
What’s the difference ? There is a boucle 0 to 7 before with a delay of 250 msec into.
With that, its works … When I reduce the size of the boucle, it starts to don’t respect the data an I have totally incoherent variables…
I don’t understand what heppen exactly… I’m working with Windows 7 64 bits, i tried with an XP 32 bits, and I have the sames problems…
I tried to build that http://www.thepenguincult.com/proyectos/arduino-delphi-lm35/ but I recieve packets incorrect too.
I tried with TComPort, TpaPro too and I’m going to the same issues…
The arduino I use is a Atmega168 and it is a clone MC-NOVE multicomp.
I think the problem is my arduino-clone board or this is the program of the arduino (synchronisation ? internal clock-time problems ? What resources use the serial communicator ?)
Thanks for your help.
Best regards.
I'm not sure what your problem is, but I'd try increasing the baud rate. 9600 is pretty slow.
numero=numero++;
The numero++ statement is equivalent to numero = numero + 1, so your statement is equivalent to numero = numero = numero + 1. Is that really what you want?
Hi.
Thanks for your answer.
In delphi, to make an increment of 1 we can write that :
numero := numero + 1;
With arduino (or C), this is it : numero=numero++;
But numero = numero + 1; works too ... What's the difference ? I don't understand this very....
But i don't think the problem is here.
I proved at 56000 K too and I got the same problem.
I receive one variable with 12345, an other of 67891011 , .....
What i want is receive 1, next time 2 , next 3 etc etc etc ...
What I want exactly is for example all the 500 Msec, the arduino send an integer number to my serial port, and be able to read it coorectly wity my delphi application.
in C++ numero++; // this will add 1 to numero all by itself numero = numero + 1; // does the same
in Delphi numero := numero + 1;
if I understand your code correctly, you are looking for #13 (CR) as a line terminator try looking for #10 (LF) instead
Hi mmcp42 :)
Thanks for your answer 8)
It is not exactly this thing I'm looking for.
The thing I'm looking is the following :
Into the loop, for example each 200 millisecond, I want to send with the serial-port an integer variable (numero), using this code :
int numero;
  numero=0;
  delay(200);
  numero=numero++;
Normally, the arduino will send each 200msec the value of the number isn't it ? (I checked it with the arduino serial monitor).
0 (nothing during 200 msec) 1 (nothing during 200 msec) 2 (nothing during 200 msec) 3 (nothing during 200 msec) etc ........
Now, with Delphi, using the ComPort component, I write this code :
procedure TMainForm.ComPort1RxChar(Sender: TObject; Count: Integer);
var
  Str: String;
begin
  ComPort1.ReadStr(Str, Count);
  label1.Caption:=Str;
end;
Now, each 200 msec, I have this value for STR :
0123 (nothing during 200 msec) 45678 (nothing during 200 msec) 910111213 (nothing during 200 msec) 1415 (nothing during 200 msec) etc ........
I don't understand what happen because with this example http://www.thepenguincult.com/proyectos/arduino-delphi-lm35/ , it's looks to work well but with my arduino, I have the same problems (I used it with a Win 7 64 Bits and and XP 32 Bits and I get the same bad issues...)
I'm thinking this is the arduino I use because this is an unofficial... I don't have any idea of what happening...
axxel: Hi mmcp42 :)
well first off put the code inside a code box in between #
int numero;
  numero=0;
  delay(200);
  numero++;
now we can read it without it taking up too much space :) you'll see I also fixed your numero++ "buglet"
axxel: Normally, the arduino will send each 200msec the value of the number isn't it ? (I checked it with the arduino serial monitor).
if it works with the serial monitor, then a) the Arduino is working correctly b) the sketch is working correctly c) the problem must be in the Delphi code
axxel: Now, with Delphi, using the ComPort component, I write this code :
var
  Str: String;
begin
  ComPort1.ReadStr(Str, Count);   label1.Caption:=Str;
end;
your code is simply dumping the results of each read into your label1 the example appends it to memo.text
you see the difference!
axxel: Now, each 200 msec, I have this value for STR :
memo objects can handle newline characters label objects cannot so any newlines will be discarded (do you see funny "blobs" sometimes?)
hope that helps
Hi mmcp42 :) !
If you were from Barcelona, I invite you to drink a good beer with pleasure to talk of this stuff with you :)
I'm totally agree with you - It's logical :)
now we can read it without it taking up too much space you'll see I also fixed your numero++ "buglet"
Now, with this example, it's works fine with delphi, exactly like the serial monitor of the Arduino Program.
Here is the sample delphi program... :roll_eyes:
http://www.megaupload.com/?d=O8QJ1HBP
Into the TMemo, everything is perfect. But sometimes I have some "glitches" so any newlines are discarded (and I funny "blobs" sometimes too) :0
Now I don't understand the "logic" very well of this system....
0
the STR value should be "0"+CHR13
1
the STR value should be "1"+CHR13
2
etc ........
What I want to do exactly is to have into my delphi program a variable of type Integer with the content of the ultimate result sended by the arduino, without using the TMemo, because it will keep all these datas into the RAM of the computer and saturate it. What I want to do looks like a straming.
I thinks this source-code dosen't works too ?
Thxxx a lot for these answers :stuck_out_tongue_closed_eyes:
what you will have to do is what TMemo does put each character into a buffer as it arrives from the com port scan the buffer looking for newline ( chr(10) or chr(13) ) anything before the newline is the characters you extract remove them from the buffer and convert to an integer
PS the sample code is terrible in just so many ways!
Hi MMCP42 :)
I've done it, thanks a lot for your help !
Have a look here, this is my awful source-code but it works very well :)
http://arduino.cc/forum/index.php/topic,65721.0.html
Best regards.
Axxel.
For more on Arduino-PC comms, with the original Pascal based Delphi, see the following... which also has many general points in it...
http://sheepdogguides.com/arduino/art4SeIntro.htm
