Arduino and DHT11, multi curves on Processing
I am a newbie using Processing and I would like to know how to draw several curves in one graph. It should not be too complicated, but the main thing is that I am using Arduino and a DHT11 sensor which monitors humidity and temperature with one digital output. What I would like to achieve is to monitor the values of humidity and temperature on Processing in one graph.
Here is the Arduino program :
#include "DHT.h"
    #define DHTPIN 2     // what pin we're connected to
    #define DHTTYPE DHT11
    // Initialize DHT sensor for normal 16mhz Arduino
    DHT dht(DHTPIN, DHTTYPE);
      dht.begin();
      int h = dht.readHumidity();
      // Read temperature as Celsius
      float t = dht.readTemperature();
      // Read temperature as Fahrenheit
      float f = dht.readTemperature(true);
      // Check if any reads failed and exit early (to try again).
      if (isnan(h) || isnan(t) || isnan(f)) {
        Serial.println("Failed to read from DHT sensor!");
        return;
      // Compute heat index
      // Must send in temp in Fahrenheit!
      float hi = dht.computeHeatIndex(f, h);
      //Serial.print("Humidity: ");
      Serial.println(h);
      //Serial.print("Temperature: ");
      Serial.print(t);
      delay(500);                        // wait 100ms for next reading
And here is the Processing program I found on the Internet :
import processing.serial.*;
    Serial myPort;        // The serial port
    int xPos = 1;         // horizontal position of the graph
    //Variables to draw a continuous line.
    int lastxPos=1;
    int lastheight=0;
    float val;
    void setup () {
      // set the window size:
      size(800, 600);
      // List all the available serial ports
      println(Serial.list());
      // Check the listed serial ports in your machine
      // and use the correct index number in Serial.list()[].
      myPort = new Serial(this, Serial.list()[0], 9600);  //
      // A serialEvent() is generated when a newline character is received :
      //myPort.bufferUntil('\n');
      background(0);      // set inital background:
    void draw () {
      if ( myPort.available() > 0) {  // If data is available,
        val = myPort.read();          // read it and store it in val
        // Convert the values to set the radius
      // everything happens in the serialEvent()
    void serialEvent (Serial myPort) {
      // get the ASCII string:
      String inString = myPort.readStringUntil('\n');
      if (inString != null) {
        inString = trim(inString);                // trim off whitespaces.
        float inByte = float(inString);           // convert to a number.
        inByte = map(inByte, 0, 100, 0, height); //map to the screen height.
        //Drawing a line from Last inByte to the new one.
        stroke(127,34,255);     //stroke color
        strokeWeight(2);        //stroke wider
        line(lastxPos, lastheight, xPos, height - inByte);
        lastxPos= xPos;
        lastheight= int(height-inByte);
        // at the edge of the window, go back to the beginning:
        if (xPos >= width) {
          xPos = 0;
          lastxPos= 0;
          background(0);  //Clear the screen.
        else {
          // increment the horizontal position:
          xPos++;
I have the feeling it should be somewhere near this line String inString = myPort.readStringUntil('\n'); but I have no idea how to extract both the temperature and moisture ; it does work with the temperature or the humidity depending on which but I don't know how to do with both.
Could you help me ?
Thanks,
The DHT11 sensor does not have any digital OUTPUT.
Why? Only one scale makes any sense where you are. Quit doing the crap you don't need to do.
      Serial.println(h);
      Serial.print(t);
Printing one value, a separator, and then the other value, followed by a carriage return and line feed makes a lot more sense.
Not when it's commented out. But that IS what you want to do.
    void draw () {
Do NOT read serial data in draw().
No, it doesn't because you commented out the call to bufferUntil().
