Arduino and dynamic_cast<WiFiEspUDP*>(pSerialSrc);
Is there any way to use this with Arduino or has anyone come up with an Arduino compatible alternative?
(deleted)
spycatcher2k:
What is it? Context, Description of function, or even a little bit of a clue would help.
Are you familiar with Windows MFC programming with their DECLARE_DYANMIC(class), IMPLMENT_DYNAMIC(class, base class> and IsKindOf(RUNTIME_CLASS(class name)) system?
class HardwareSerial and class WiFiEspUDP are both derived from Stream.
I would like to pass in a pointer to either a HardwareSerial object or a WiFiEspUDP object.
And inside my function I would like to be able to tell which object it is so I know whether or not to do this:
bool CSerialManager::writeWord(Stream *pSerialSrc, const __FlashStringHelper *strBuff)
	WiFiEspUDP* pUDPServer = dynamic_cast<WiFiEspUDP*>(pSerialSrc);
	if (pUDPServer)
		pUDPServer->beginPacket(pUDPServer->remoteIP(), pUDPServer->remotePort());
	pSerialSrc->print(strBuff);
	pSerialSrc->print("#");
	if (pUDPServer)
		pUDPServer->endPacket();
The alternative is to have serparate functions for class HardwareSerial and class WiFiEspUDP, which is rather inconvenient given that there are a number of similar functions.
Normally, UDP classes are derived from Arduino UDP class.
So, you can do something like this:
bool CSerialManager::writeWord(UDP *pUdpSrc, const __FlashStringHelper *strBuff)
	WiFiEspUDP* pUDPServer = dynamic_cast<WiFiEspUDP*>(pUdpSrc);
	if (pUDPServer)
	writeWord((Stream*) pUdpSrc, strBuff);
	if (pUDPServer)
Sorry I did not make it clear. dynamic_cast generates a compile error along the lines of you can't use it with compiler option -f......
What about:
	pUdpSrc->beginPacket(pUdpSrc->remoteIP(), pUdpSrc->remotePort());
	pUdpSrc->endPacket();
and calling:
WiFiEspUDP* pUDPServer;
myCSerialManager.writeWord(pUDPServer,F("just a test"));
