Arduino and eps8266
hello all…
i have this code and sometimes working but working with delay can help me anyone? i need to open one led from my mobile direct with esp8266…my code is:
#include <SoftwareSerial.h>
#define DEBUG true
SoftwareSerial esp8266(11,10); // make RX Arduino line is pin 11, make TX Arduino line is pin 10.
// This means that you need to connect the TX line from the esp to the Arduino’s pin 11
// and the RX line from the esp to the Arduino’s pin 10
esp8266.begin(115200); // your esp’s baud rate might be different
pinMode(8,OUTPUT);
digitalWrite(8,LOW);
pinMode(6,OUTPUT);
digitalWrite(6,LOW);
pinMode(9,OUTPUT);
digitalWrite(9,LOW);
Serial.println(sendData(“AT+RST\r\n”,2000,DEBUG)); // reset module
Serial.println(sendData(“AT+CWMODE=3\r\n”,1000,DEBUG)); // configure as access point AP=2, STA=1, 3=BOTH
Serial.println(sendData(“AT+CIFSR\r\n”,1000,DEBUG)); // get ip address
Serial.println(sendData(“AT+CIPMUX=1\r\n”,1000,DEBUG)); // configure for multiple connections
Serial.println(sendData(“AT+CIPSERVER=1,80\r\n”,1000,DEBUG)); // turn on server on port 80
/* String t;
while (esp8266.available())
t+=(char)esp8266.read();//read byte,convert to char and append it to string
}//end while
Serial.println(t);
delay(2000);
if (t.length())
{ // if string is not empty
if (t=="/?on")
digitalWrite(9, HIGH);
Serial.write(“LED is ON \n”);
}//end if
else if (t=="+IPD,0,457=GET /?off HTTP/1.1")
digitalWrite(9, LOW);
Serial.write(“LED is OFF \n”);
}//end if
if(esp8266.available()) // check if the esp is sending a message
if(esp8266.find("+IPD,"))
delay(1000); // wait for the serial buffer to fill up (read all the serial data)
// get the connection id so that we can then disconnect
int connectionId = esp8266.read()-48; // subtract 48 because the read() function returns
// the ASCII decimal value and 0 (the first decimal number) starts at 48
String t;
esp8266.find("/?"); // advance cursor to “pin=”
if (t.length()==2){break;}
// t=(char)esp8266.read();
// t+=(char)esp8266.read();
Serial.println(t);
if(t==“on”)
digitalWrite(8, HIGH);
else if(t==“of”)
digitalWrite(8, LOW);
if(t==“6o”)
digitalWrite(6, HIGH);
else if(t==“6f”)
digitalWrite(6, LOW);
esp8266.find(“pin=”); // advance cursor to “pin=”
int pinNumber = (esp8266.read()-48)*10; // get first number i.e. if the pin 13 then the 1st number is 1, then multiply to get 10
pinNumber += (esp8266.read()-48); // get second number, i.e. if the pin number is 13 then the 2nd number is 3, then add to the first number
digitalWrite(pinNumber, !digitalRead(pinNumber)); // toggle pin
// make close command
String closeCommand = “AT+CIPCLOSE=”;
closeCommand+=connectionId; // append connection id
closeCommand+="\r\n";
sendData(closeCommand,1000,DEBUG); // close connection.
}//loop
  • Name: sendData
  • Description: Function used to send data to ESP8266.
  • Params: command - the data/command to send; timeout - the time to wait for a response; debug - print to Serial window?(true = yes, false = no)
  • Returns: The response from the esp8266 (if there is a reponse)
    String sendData(String command, const int timeout, boolean debug)
    String response = “”;
esp8266.print(command); // send the read character to the esp8266
long int time = millis();
while( (time+timeout) > millis())
while(esp8266.available())
// The esp has data so display its output to the serial window
char c = esp8266.read(); // read the next character.
response+=c;
if(debug)
Serial.print(response);
return response;
That comment is nonsense. It is NOT how to read serial data properly. The sender needs to send some kind of end of packet marker. The receiver needs to read and store data, starting when the + arrives (do NOT use find()), stopping when the end of packet marker arrives. It may take a 100,000 passes through loop() for that to happen. But, so what? The number of iterations of loop() is irrelevant.
What is relevant is that there is NO delay().
hello again i am noob in arduino can you fix my code? when i use application from android the respone time is not good... i have to wait 2-3 sec to give the next command to work, and that is problem cause i want to control car with this... Sorry for my english... if u want something else tell me plz!
my application have 4 buttons and i use code on event button press(forward) and button release(stop). on button press i send (Http://192.168.4.1/?on) and on release i send (Http://192.168.4.1/?of)
i hope that help you!
That doesn't help me at all. It is QUITE clear what your problem is. Get rid of the stupid delay() call.
