Hi! I have build a soil condition monitoring system using Arduino Nano and Esp32 to send the measured data to Thingspeak server. The Nano and Esp32 are communicating through TX and RX pins. I tought that the RX in Esp32 goes to TX in Arduino? If I put the pins other way the serial monitor of Esp32 shows the same values Arduino measures with the sensors. If I put the wires to the pins how they should go, the serial monitor of Esp32 shows 0 for all the values? Esp32 connects to wifi and sends the data to thingspeak but only the 0 values, not the correct ones.
I have tested the esp32 and it receives bytes from Arduino but I think it does not know how to sort them into different values. Please help.
Here is Arduinos code:
[10.54] Anton Store
#include <SPI.h>
#include <SoftwareSerial.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 5
#define RE 8
#define DE 7
const byte code[] = {0x01, 0x03, 0x00, 0x1e, 0x00, 0x03, 0x65, 0xCD};
byte values[11];
SoftwareSerial mod(2, 3);
const int AirValue = 645; //you need to replace this value with Value_1
const int WaterValue = 254; //you need to replace this value with Value_2
int soilMoistureValue = 0;
int soilmoisturepercent = 0;
float temperature;
int nitrogen;
int phosphorous;
int potassium;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
struct MyVariable
byte soilmoisturepercent;
byte nitrogen;
byte phosphorous;
byte potassium;
byte temperature;
MyVariable variable;
mod.begin(115200);
sensors.begin();
pinMode(RE, OUTPUT);
pinMode(DE, OUTPUT);
byte val;
digitalWrite(DE, HIGH);
digitalWrite(RE, HIGH);
delay(10);
if (mod.write(code, sizeof(code)) == 8)
digitalWrite(DE, LOW);
digitalWrite(RE, LOW);
for (byte i = 0; i < 11; i++)
//Serial.print(mod.read(),HEX);
values[i] = mod.read();
Serial.print(values[i], HEX);
nitrogen = values[4];
phosphorous = values[6];
potassium = values[8];
delay(1500);
soilMoistureValue = analogRead(A0); //put Sensor into soil
//Serial.println(soilMoistureValue);
soilmoisturepercent = map(soilMoistureValue, AirValue, WaterValue, 0, 100);
if (soilmoisturepercent >= 100)
soilmoisturepercent = 100;
else if (soilmoisturepercent <= 0)
else if (soilmoisturepercent > 0 && soilmoisturepercent < 100)
soilmoisturepercent = soilmoisturepercent;
delay(1500);
sensors.requestTemperatures();
temperature = sensors.getTempCByIndex(0);
variable.soilmoisturepercent = soilmoisturepercent;
variable.nitrogen = nitrogen;
variable.phosphorous = phosphorous;
variable.potassium = potassium;
variable.temperature = temperature;
delay(1500);
Serial.print("Soil Moisture: ");
Serial.print(variable.soilmoisturepercent);
Serial.println("%");
Serial.print("Nitrogen: ");
Serial.print(variable.nitrogen);
Serial.println(" mg/kg");
Serial.print("Phosphorous: ");
Serial.print(variable.phosphorous);
Serial.print("Potassium: ");
Serial.print(variable.potassium);
Serial.print("Temperature: ");
Serial.print(variable.temperature);
Serial.println("*C");
Serial.println("Data Packet Sent");
Serial.println("");
delay(10000);
And here is the code for Esp32:
#include <WiFi.h>
#include <SPI.h>
String apiKey = "FSHD2JR6VANGPC2U";
const char* ssid = "OnePlus5T";
const char* password = "********";
const char* server = "api.thingspeak.com";
int incomingByte = 0;
struct MyVariable
byte nitrogen;
byte phosphorous;
byte potassium;
byte temperature;
WiFiClient client;
Serial.println("Receiver Started....");
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
// say what you got:
Serial.print("I received: ");
Serial.println(incomingByte, DEC);
else Serial.print("I received nothing ");
if (client.connect(server, 80))
String postStr = apiKey;
postStr += "&field1=";
postStr += String(variable.soilmoisturepercent);
postStr += "&field2=";
postStr += String(variable.nitrogen);
postStr += "&field3=";
postStr += String(variable.phosphorous);
postStr += "&field4=";
postStr += String(variable.potassium);
postStr += "&field5=";
postStr += String(variable.temperature);
postStr += "\r\n\r\n\r\n\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
delay(10000);
Serial.println("Data Sent to Server");
client.stop();
