Arduino and Hackvision Worm
Hello
I was traying to make arduino snake console. I fund the code for snake in the internet and downloaded it, but when i try to compile it this error pops out. I am using original Arduino Uno.
site from wchich i have downloaded code: https://nootropicdesign.com/hackvision/games.html
What error?
Post all your code and all the error message.
Please post the actual code instead of a picture of it and use code tags when you post it
I have sent the scrrenshot in attachment.
Amforev:
We do NOT want to see pictures of text. Post the text AS TEXT. Or, don't let the door hit you in the ass on the way out. Or do, I don't care.
#include <avr/pgmspace.h>
#include <TVout.h>
#include <video_gen.h>
#include <fontALL.h>
#include <Controllers.h>
#define TV_W 136
#define TV_H 98
#define FRAME_X0 8
#define FRAME_X1 128
#define FRAME_Y0 9
#define FRAME_Y1 89
#define LEFT 3
#define RIGHT 2
#define UP 4
#define DOWN 5
#define FIRE 10
struct Segment
  boolean active;
  byte x;
  byte y;
prog_char s0[] PROGMEM = "ARDUINO WORM";
prog_char s1[] PROGMEM = "GAME";
prog_char s2[] PROGMEM = "OVER";
prog_char s3[] PROGMEM = "SCORE: ";
PROGMEM const char *strings[] = {
  s0,s1,s2,s3};
char s[16]; // general string buffer
char scoreString[11];
byte currentTonePriority = 0;
byte ballX;
byte ballY;
byte movingDirection;
boolean ballCollected = false;
int currentScore;
Segment worm[50];
void (*game)();
TVout tv;
// Allow the overall speed of the game to be adjusted.
// Higher number (like 1.5) slow the game down.  Lower numbers (like 0.6) speed it up.
float speedAdjust = 1.0;
void setup()  {
  // If pin 12 is pulled LOW, then the PAL jumper is shorted.
  pinMode(12, INPUT);
  digitalWrite(12, HIGH);
  if (digitalRead(12) == LOW) {
    tv.begin(_PAL, TV_W, TV_H);
    // Since PAL processing is faster, we need to slow the game play down.
    speedAdjust = 1.4;
  else {
    tv.begin(_NTSC, TV_W, TV_H);
  tv.select_font(font6x8);
  randomSeed(analogRead(0));
  playTone(1046, 20);
  tv.delay(1);
  playTone(1318, 20);
  tv.delay(1);
  playTone(1568, 20);
  tv.delay(1);
  playTone(2093, 20);
  byte m[1] = {0};
  byte choice = menu(1, m);
  if (choice == 0) {
    game = &worms;
    tv.delay(10);
    initWorms();
byte menu(byte nChoices, byte *choices) {
  char choice = 0;
  tv.fill(0);
  byte x = 24;
  byte y;
  while (true) {
    for(byte i=0;i<nChoices;i++) {
      strcpy_P(s, (char *)pgm_read_word(&(strings[choices[i]])));
      tv.print(32, 30+(i*8), s);
      y = 30+(i*8);
      if (i == choice) {
        // draw arrow next to selected game
        tv.set_pixel(x+4, y, 1);
        tv.set_pixel(x+5, y+1, 1);
        tv.draw_line(x, y+2, x+6, y+2, 1);
        tv.set_pixel(x+5, y+3, 1);
        tv.set_pixel(x+4, y+4, 1);
      else {
        for(byte j=0;j<8;j++) {
          tv.draw_line(x, y+j, x+7, y+j, 0);
    // get input
    if (pollFireButton(10)) {
      playTone(1046, 20);
      return choice;
    if (Controller.upPressed()) {
      choice--;
      if (choice == -1) {
        choice = 0;
      else {
        playTone(1046, 20);
    if (Controller.downPressed()) {
      choice++;
      if (choice == nChoices) {
        choice = nChoices-1;
      else {
        playTone(1046, 20);
void initWorms() {
  for(int x = 0; x < 5; x++) {
    worm[x].active = true;
    worm[x].x = 30-x;
    worm[x].y = 30;
  for(int x = 5; x < 50; x++) {
    worm[x].active = false;
    worm[x].x = 0;
    worm[x].y = 0;
  movingDirection = RIGHT;
  ballCollected = true;
  currentScore = 0;
  updateScore();
  game();
void worms() {
  tv.fill(0);
  drawFrame();
  drawScore();
  drawBall();
  for(int x = 0; x < 50; x++) {
    if(worm[x].active)
      tv.set_pixel(worm[x].x,worm[x].y,1);
  move();
  tv.delay_frame(4);
void drawBall() {
  if(ballCollected) {
    ballX = random(FRAME_X0+1, FRAME_X1-1);
    ballY = random(FRAME_Y0+1, FRAME_Y1-1);
  tv.set_pixel(ballX,ballY,1);
void drawFrame() {
  tv.draw_line(FRAME_X0, FRAME_Y0, FRAME_X1, FRAME_Y0, 1);
  tv.draw_line(FRAME_X0, FRAME_Y1, FRAME_X1, FRAME_Y1, 1);
  tv.draw_line(FRAME_X0, FRAME_Y0, FRAME_X0, FRAME_Y1, 1);
  tv.draw_line(FRAME_X1, FRAME_Y0, FRAME_X1, FRAME_Y1, 1);
void move() {
    if(movingDirection != DOWN) {
      movingDirection = UP;
  else if(Controller.downPressed()) {
    if(movingDirection != UP) {
    movingDirection = DOWN;
  else if(Controller.leftPressed()) {
    if(movingDirection != RIGHT) {
    movingDirection = LEFT;
  else if(Controller.rightPressed()) {
    if(movingDirection != LEFT) {
  switch (movingDirection) {
  case UP:
    if(detectBallHit(worm[0].x, worm[0].y-1)) {
      assignBallCoordinatesToFirstSegment();
    else {
      shiftSegments();
      worm[0].y = worm[0].y-1   ;
  case DOWN:
    if(detectBallHit(worm[0].x, worm[0].y+1)){
    else {
      shiftSegments();
      worm[0].y = worm[0].y+1   ;
  case LEFT:
    if(detectBallHit(worm[0].x-1, worm[0].y)){
    else {
      shiftSegments();
      worm[0].x = worm[0].x-1   ;
  case RIGHT:
    if(detectBallHit(worm[0].x+1, worm[0].y)){
    else {
      shiftSegments();
      worm[0].x = worm[0].x+1   ;
   if(worm[0].x > FRAME_X1-1 || worm[0].x < FRAME_X0+1 || worm[0].y > FRAME_Y1-1 || worm[0].y < FRAME_Y0+1 || checkForTailBite()) {
    gameOver();
    initWorms();
    return;
boolean checkForTailBite() {
  for(int x = 1; x < 50; x++) {
    if(worm[0].x == worm[x].x && worm[0].y == worm[x].y) {
      return true;
  return false;
void shiftSegments() {
  for(int x = 49; x > 0; x--) {
    if(worm[x].active) {
      worm[x].x = worm[x-1].x;
      worm[x].y = worm[x-1].y;
void assignBallCoordinatesToFirstSegment() {
  worm[0].x = ballX;
  worm[0].y = ballY;
boolean detectBallHit(byte sx, byte sy) {
  if(sx == ballX && sy == ballY) {
    for(int x = 49; x > -1; x--) {
        worm[x+1].active = true;
        worm[x+1].x = worm[x].x;
        worm[x+1].y = worm[x].y;
    currentScore += 1;
    updateScore();
    playTone(1046, 10);
    tv.delay(1);
    playTone(1318, 10);
    tv.delay(1);
    playTone(1568, 10);
    tv.delay(1);
    playTone(2093, 10);
    return true;
  else {
    return false;
void drawScore() {
  tv.print(FRAME_X0, 0, scoreString);
void updateScore() {
  strcpy_P(scoreString, (char *)pgm_read_word(&(strings[3])));
  sprintf(s, "%d", currentScore);
  strcat(scoreString, s);
void gameOver() {
  tv.delay(1000);
  tv.fill(0);
  strcpy_P(s, (char *)pgm_read_word(&(strings[1])));
  tv.print(44, 40, s);
  strcpy_P(s, (char *)pgm_read_word(&(strings[2])));
  tv.print(72, 40, s);
  tv.delay(3000);
boolean pollFireButton(int n) {
  for(int i=0;i<n;i++) {
    tv.delay_frame(1);
    if (Controller.firePressed()) {
      return true;
  return false;
void playTone(unsigned int frequency, unsigned long duration_ms) {
  // Default is to play tone with highest priority.
  playTone(frequency, duration_ms, 9);
void playTone(unsigned int frequency, unsigned long duration_ms, byte priority) {
  // priority is value 0-9, 9 being highest priority
  if (TCCR2B > 0) {
    // If a tone is currently playing, check priority
    if (priority < currentTonePriority) {
      return;
  currentTonePriority = priority;
  tv.tone(frequency, duration_ms);
Which version of the IDE are you using ?
1.8.5
Where are the errors you are getting? Surely you don’t expect us to hunt for, and download all those libraries, so we can reproduce the errors that you are seeing but not sharing.
Arduino:1.8.5 (Windows 10), Płytka:"Arduino/Genuino Uno"
ArduinoWorm:27: error: 'prog_char' does not name a type
ArduinoWorm:28: error: 'prog_char' does not name a type
ArduinoWorm:29: error: 'prog_char' does not name a type
ArduinoWorm:30: error: 'prog_char' does not name a type
ArduinoWorm:32: error: variable 'strings' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
ArduinoWorm:33: error: 's0' was not declared in this scope
   s0,s1,s2,s3};
ArduinoWorm:33: error: 's1' was not declared in this scope
   s0,s1,s2,s3};
ArduinoWorm:33: error: 's2' was not declared in this scope
   s0,s1,s2,s3};
ArduinoWorm:33: error: 's3' was not declared in this scope
   s0,s1,s2,s3};
exit status 1
Błędna biblioteka znaleziona w C:\Program Files (x86)\Arduino\libraries\arduino: C:\Program Files (x86)\Arduino\libraries\arduino
Ten raport powinien zawierać więcej informacji jeśli w
File -> Preferencje zostanie włączona opcja "Pokaż
szczegółowe informacje podczas kompilacji"
[code]
Błędna biblioteka means wrong library.
Here
But how to repair that? The line #include <avr/pgmspace.h> is already in the code and it does not work.
Syntax
const dataType variableName PROGMEM = {data0, data1, data3…​};
Yes, it does.
prog_char is no longer a supported type. char is, and always will be.
Some information on the prog_char thing here:
