Hi everyone,
I am using the SAMD21 mini breakout ( SparkFun SAMD21 Mini Breakout - DEV-13664 - SparkFun Electronics ) and the MAX30102 Heart rate board ( https://www.maximintegrated.com/en/design/reference-design-center/system-board/6300.html ).
I am trying to communicate with this over I2C and have been able to use other I2C devices such as an accelerometer and display with the SAMD21 but am obtaining the following errors:
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h: In function 'void i2c_start_wait(uint8_t)':
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h:182:46: error: '_SFR_IO_ADDR' was not declared in this scope
#define SDA_DDR (_SFR_IO_ADDR(SDA_PORT) - 1)
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h:352:24: note: in expansion of macro 'SDA_DDR'
: : [SDADDR] "I" (SDA_DDR), [SDAPIN] "I" (SDA_PIN),
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h: In function 'void i2c_stop()':
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h:183:46: error: '_SFR_IO_ADDR' was not declared in this scope
#define SCL_DDR (_SFR_IO_ADDR(SCL_PORT) - 1)
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h:372:25: note: in expansion of macro 'SCL_DDR'
: : [SCLDDR] "I" (SCL_DDR), [SCLPIN] "I" (SCL_PIN), [SCLIN] "I" (SCL_IN),
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h: In function 'bool i2c_write(uint8_t)':
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h:448:22: note: in expansion of macro 'SCL_DDR'
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h: In function 'uint8_t i2c_read(bool)':
C:\Users\Daniel\Documents\Arduino\libraries\Maxim\SoftI2CMaster.h:517:22: note: in expansion of macro 'SCL_DDR'
How do I fix this problem?
Is it because this device is not using the Wire library. Can I use the Wire lib instead?
The library can be found : GitHub - MaximIntegratedRefDesTeam/RD117_ARDUINO: MAXREFDES117 firmware for Arduino platforms
Here is a copy of the partial code:
#include <SAMD_AnalogCorrection.h>
#include <Arduino.h>
#include "algorithm.h"
#include "max30102.h"
#define MAX_BRIGHTNESS 255
#if defined(ARDUINO_AVR_UNO)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
uint16_t aun_ir_buffer[100]; //infrared LED sensor data
uint16_t aun_red_buffer[100]; //red LED sensor data
#else
uint32_t aun_ir_buffer[100]; //infrared LED sensor data
uint32_t aun_red_buffer[100]; //red LED sensor data
#endif
int32_t n_ir_buffer_length; //data length
int32_t n_spo2; //SPO2 value
int8_t ch_spo2_valid; //indicator to show if the SPO2 calculation is valid
int32_t n_heart_rate; //heart rate value
int8_t ch_hr_valid; //indicator to show if the heart rate calculation is valid
uint8_t uch_dummy;
// the setup routine runs once when you press reset:
maxim_max30102_reset(); //resets the MAX30102
// initialize serial communication at 115200 bits per second:
SerialUSB.begin(115200);
pinMode(9, INPUT); //pin D10 connects to the interrupt output pin of the MAX30102
maxim_max30102_read_reg(REG_INTR_STATUS_1,&uch_dummy); //Reads/clears the interrupt status register
maxim_max30102_init(); //initialize the MAX30102
// the loop routine runs over and over again forever:
uint32_t un_min, un_max, un_prev_data, un_brightness; //variables to calculate the on-board LED brightness that reflects the heartbeats
int32_t i;
float f_temp;
un_brightness=0;
un_min=0x3FFFF;
un_max=0;
n_ir_buffer_length=100; //buffer length of 100 stores 4 seconds of samples running at 25sps
//read the first 100 samples, and determine the signal range
for(i=0;i<n_ir_buffer_length;i++)
while(digitalRead(9)==1); //wait until the interrupt pin asserts
maxim_max30102_read_fifo((aun_red_buffer+i), (aun_ir_buffer+i)); //read from MAX30102 FIFO
if(un_min>aun_red_buffer[i])
un_min=aun_red_buffer[i]; //update signal min
if(un_max<aun_red_buffer[i])
un_max=aun_red_buffer[i]; //update signal max
un_prev_data=aun_red_buffer[i];
//calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
maxim_heart_rate_and_oxygen_saturation(aun_ir_buffer, n_ir_buffer_length, aun_red_buffer, &n_spo2, &ch_spo2_valid, &n_heart_rate, &ch_hr_valid);
//Continuously taking samples from MAX30102. Heart rate and SpO2 are calculated every 1 second
while(1)
i=0;
un_min=0x3FFFF;
un_max=0;
//dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
for(i=25;i<100;i++)
aun_red_buffer[i-25]=aun_red_buffer[i];
aun_ir_buffer[i-25]=aun_ir_buffer[i];
//update the signal min and max
//take 25 sets of samples before calculating the heart rate.
for(i=75;i<100;i++)
un_prev_data=aun_red_buffer[i-1];
digitalWrite(8, !digitalRead(8));
//calculate the brightness of the LED
if(aun_red_buffer[i]>un_prev_data)
f_temp=aun_red_buffer[i]-un_prev_data;
f_temp/=(un_max-un_min);
f_temp*=MAX_BRIGHTNESS;
f_temp=un_brightness-f_temp;
if(f_temp<0)
un_brightness=0;
un_brightness=(int)f_temp;
f_temp=un_prev_data-aun_red_buffer[i];
un_brightness+=(int)f_temp;
if(un_brightness>MAX_BRIGHTNESS)
un_brightness=MAX_BRIGHTNESS;
#if defined(ARDUINO_AVR_LILYPAD_USB)
analogWrite(13, un_brightness);
#endif
#if defined(ARDUINO_AVR_FLORA8)
LED.setPixelColor(0, un_brightness/BRIGHTNESS_DIVISOR, 0, 0);
LED.show();
#endif
//send samples and calculation result to terminal program through UART
SerialUSB.print(("red="));
SerialUSB.print(aun_red_buffer[i], DEC);
SerialUSB.print((", ir="));
SerialUSB.print(aun_ir_buffer[i], DEC);
SerialUSB.print((", HR="));
SerialUSB.print(n_heart_rate, DEC);
SerialUSB.print((", HRvalid="));
SerialUSB.print(ch_hr_valid, DEC);
