Arduino and HOPE RF HM-TRS serial communication problem
I want to connect arduino uno smd with my computer wireless with Hope RF HM-TRS wireless transparent module, i've put the code byte high = 0;
// 2 Stop-bits please!
UCSR0C = UCSR0C | B00001000;
pinMode(13, OUTPUT);
if (high == 0)
digitalWrite(13, HIGH);
high = 1;
digitalWrite(13, LOW);
high = 0;
if (high == 0)
Serial.print("HELLO"); // The text
Serial.print("WORLD"); // The text
and on the computer i recive << ... for Hello and TX<<O for World. The modules are with default settings 9600, 8 , N.
What to do get data corectly?
datasheet? Wiring diagram?
http://www.hoperf.com/upload/rf_app/HM-TRS.pdf this is the datasheet for wireless module, i've connected arduino's RX to TX on module and TX from arduino to RX on module as shown in datasheet.
You read the datasheet about the power supply being 2.2V to 3.8V then?
yes, i use arduino 3.3 V power suply
grounds and power lines shared I presume? Reread datasheet for any thing you've missed, check all connections with multimeter?
i will recheck all to see if is something wrong. tnx
