Arduino and java -swing-
I would like to share this demo program, that shows how to open a serial connection
to an Arduino, and send it data, (input from a JTextField)
When the arduino sends data back, it is shown on a JTextArea.
When there is a connection, a LED burns.
Tested on Win2K. Availble port was COM4
The package gnu.io is used.
copy rxtx.jar in \jre\lib\ext and
rxtx.dll in jre\bin
Java code:
import gnu.io.CommPort;
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import gnu.io.SerialPortEvent;
import gnu.io.SerialPortEventListener;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class SerialReader_Swing extends JFrame implements ActionListener,
      SerialPortEventListener{
//members*****s******************************************
JButton jButton_connect = null;
JButton jButton_clear = null;
JButton jButton_send = null;
JTextArea jTextArea = null;
JTextField jTextField = null;
Led led_connected = null;
boolean connected = false;
CommPort commPort = null;
SerialPort serialPort = null;
InputStream inputStream = null;
OutputStream outputStream = null;
//constructors******************************************
    public SerialReader_Swing(){
        super();
            //setDefaultCloseOperation(WindowConstants.DISPOSE_ON_CLOSE);
            addWindowListener(new WindowAdapter(){
                  public void windowClosing(WindowEvent we){
                        if (connected){
                              closeConnection();
                        dispose();
                        System.exit(0);
            jButton_connect = new JButton("Connect | STOP");
            jButton_connect.addActionListener(this);
            jButton_clear = new JButton("Clear");
            jButton_clear.addActionListener(this);
            jTextArea = new JTextArea(20,32);
            jTextArea.setEditable(false);
            jTextField = new JTextField(24);
            jButton_send = new JButton("SEND");
            jButton_send.addActionListener(this);
            led_connected = new Led(Color.GREEN,false);
            Container cont = getContentPane();
            cont.setLayout(new BoxLayout(cont,BoxLayout.Y_AXIS));
            cont.add(new JScrollPane(jTextArea,
                  JScrollPane.VERTICAL_SCROLLBAR_ALWAYS,
                  JScrollPane.HORIZONTAL_SCROLLBAR_ALWAYS));
            cont.add(jButton_clear);
            cont.add(Box.createVerticalStrut(5));
            Box hBox = Box.createHorizontalBox();
            hBox.add(jButton_connect);
            hBox.add(Box.createHorizontalStrut(5));
            hBox.add(led_connected);
            cont.add(hBox);
            hBox.add(new JScrollPane(jTextField));
            hBox.add(jButton_send);
            cont.add(hBox);
            pack();
            setVisible(true);
//implemented methods (from interfaces)*****************
      public void actionPerformed(ActionEvent e){
            if (e.getSource()==jButton_clear){
                  jTextArea.setText("");
            if (e.getSource()==jButton_send){
                  if (connected==false){
                        JOptionPane.showMessageDialog(this,
                              "Make a connection first!");
                  if (jTextField.getText().length()>0){
                        new SerialWriter(jTextField.getText()).start();
                        jTextField.setText("");
            if (e.getSource()==jButton_connect){
                        new ConnectionMaker().start();
                  }else{
                        closeConnection();
      public void serialEvent(SerialPortEvent arg0) {
            byte[] buffer = new byte[1024];
        int data;
            try{
                  int len = 0;
                  while ( ( data = inputStream.read()) > -1 ){
                        if ( data == '\n' )break;
                        buffer[len++] = (byte) data;
                  String string = new String(buffer,0,len);
                  jTextArea.setText(jTextArea.getText()+'\n'+string);
            }catch ( IOException e ){
            e.printStackTrace();
//our own methods ***************************************
      void closeConnection(){
             try{
                  inputStream.close();
            }catch (Exception ex){
                  ex.printStackTrace();
             try{
                  outputStream.close();
            try{
                  commPort.close();
            connected=false;
            led_connected.setOn(false);
    void connect( ) throws Exception {
            String portName = "COM4";
        CommPortIdentifier portIdentifier = CommPortIdentifier.getPortIdentifier(portName);
        if ( portIdentifier.isCurrentlyOwned()){
            System.out.println("Error: Port is currently in use");
        }else{
            commPort = portIdentifier.open(this.getClass().getName(),2000);
             if ( commPort instanceof SerialPort ){
                serialPort = (SerialPort) commPort;
                serialPort.setSerialPortParams(9600,SerialPort.DATABITS_8,SerialPort.STOPBITS_1,SerialPort.PARITY_NONE);
                inputStream = serialPort.getInputStream();
                        outputStream = serialPort.getOutputStream();
                serialPort.addEventListener(this);
                //serialPort.notifyOnDataAvailable(true);
                  }else{
                System.out.println("Error: Only serial ports are handled by this example.");
            //wait some time
                  try{
                        Thread.sleep(300);
                  }catch (InterruptedException ie){};
//innerclasses******************************************
      public class ConnectionMaker extends Thread{
                  public void run(){
                        //try to make a connection
                        try{
                              connect();
                        }catch ( Exception ex ){
                        //test the connection
                        try{
                              int data = -1;
                              while ( ( data = inputStream.read())<0 ){
                                    //outputStream.write('R');
                                    try{
                                          this.sleep(100);
                                    if (led_connected.getOn()){
                                    }else{
                                          led_connected.setOn(true);
                        }catch ( IOException ioe ){
                              ioe.printStackTrace();
                        //show status
                        connected=true;
                        //send ack
                        new SerialWriter("Ready").start();
      }//end innerclass
    public class SerialWriter extends Thread{
            char[] charArray = null;
            SerialWriter(String string){
                  charArray = string.toCharArray();
        public void run (){
            try{
                for (int i=0;i<charArray.length ;i++ ){
                    outputStream.write(charArray[i]);
                System.exit(-1);
    }//end innerclass
      class Led extends JPanel{
            boolean on = true;
            Color color_on = null;
            Color color_off = null;
            Led(Color color,boolean on_off){
                  color_on = color;
                  color_off = color.darker().darker().darker();
                  Dimension dimension = new Dimension(17,17);
                  setMinimumSize(dimension);
                  setPreferredSize(dimension);
                  setMaximumSize(dimension);
                  setOn(on_off);
            public void setOn(boolean on_off){
                  on = on_off;
                  repaint();
            public boolean getOn(){
                  return on;
            public void paintComponent(Graphics g){
                  super.paintComponent(g);
                  Graphics2D g2D = (Graphics2D)g;
                  g2D.setColor(Color.DARK_GRAY);
                  g2D.fillOval(0,0,getWidth(),getHeight());
                  if(on){
                        g2D.setColor(color_on);
                  }else{
                        g2D.setColor(color_off);
                  g2D.fillOval(1,1,getWidth()-1,getHeight()-1);
      }//end innerclass
//Ha! our main  :)***************************************
    public static void main ( String[] args ){
            new SerialReader_Swing();
}//end class
The code for the arduino:
int ledPin = 13;           // LED connected to the Wiring I/O board pin 0
unsigned long milliseconds = 0;
boolean ledOn = false;
void setup(){
  milliseconds = millis();
  pinMode(ledPin, OUTPUT); // sets the digital pin as output
 establishContact();  //for testing
void loop(){
  byte inByte = 0;
  if (Serial.available() > 0) {
   inByte = Serial.read();
   Serial.print(inByte,BYTE);
  blink();
 void blink(){
    if (millis() - milliseconds>=1000){
      if(ledOn){
          digitalWrite(ledPin,LOW);
          ledOn=false;
      }else{
          digitalWrite(ledPin,HIGH);
          ledOn=true;
      milliseconds=millis();
 void establishContact() {
   while (Serial.available() <= 0) {
     Serial.print(">");   // send an initial string
   Serial.println("Ready");
