I'm pretty new to electronics and I'm trying to create a LED display with some simple blinking lights. I just need some help to look over my circuit and if it will work as intended before i try building it.
The idea is for the outermost 8 LEDs to be continuously turned on. The other rows will blink inwards starting with the top one and repeating when getting to the bottom one. This will be controlled by the MOSFETs using the arduino. 220R resistors between Gate and arduino to limit current and protect and then 10kR resistors between gate and ground to keep the MOSFETs off when the arduino isn't driving them.
The power source is 12V, the LEDs have appropriate resistors, i just didn't put them in for space. The transistors are N-channel MOSFET logic gates (probably irl540n). The potentiometer at the arduino is there to control the blinking speed.
Regarding LEDs in series, sure, i know i could have better efficiency doing series of LEDs in parallel but the way this setup is going to be used I'd rather do everything in parallel.
If a bank of LEDs shares a resistor the current to each is not controlled - only the total current. As the intensity is proportional to the current you may find some are brighter than others.
You can only do this if they are all the same type - and color.
A much better way would be for the leds to be in series, that way the current through each is the same.
You havent said if you intend to use different colors - it matters. best if you share a link to the types you intend to use.
