Arduino and Matlab
Hi there,
I originally took the project from internet (Ultrasonic map-maker), but it was using 1 ultrasonic sensor and I aim to use 2 ultrasonic sensors and therefore scan 360 degrees. Here is the arduino code
#include <Servo.h>
#include <NewPing.h>
#define TRIGGER_PIN  12
#define ECHO_PIN     13
#define TRIGGER_PIN1 5
#define ECHO_PIN1    4
#define MAX_DISTANCE 350
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
NewPing sonar1(TRIGGER_PIN1, ECHO_PIN1, MAX_DISTANCE);
Servo myservo;
int pos = 0;
int times;
int servoPin = 11;
  myservo.attach(servoPin);
  delay(2000);
  int times = 0;
  int a = 0;
  int b = 0;
  for (int i = 0; i<180; i++){
    unsigned int uS = sonar.ping();
    unsigned int uS1 = sonar1.ping();
    myservo.write(i);
    delay(5);
    times = 10;
    for (int j=0; j<times; j++){
      uS = sonar.ping();
      a = uS/US_ROUNDTRIP_CM + a;
      delay(10);
      b = uS1/US_ROUNDTRIP_CM + b;
      delay(10);
    //take average
    a = a/times;
    if(a>350){  a=350;  }
    if(a<3){  a=3;  }
    b = b/times;
    if(b>350){  b=350;  }
    if(b<3){  b=3;   }
    Serial.println(a);
    delay(30);
    Serial.println(b);
  delay(5000);
I have a problem with matlab it is giving an errors which are;
Subscript indices must either be real positive integers or logicals.
Error in pro (line 12)
  • num1(i) = str2num(A);*
Here is my matlab code.
delete(instrfindall);
theta = 0:(pi/180):pi;
sPort = serial('COM9','BaudRate',9600,'DataBits',7);
fopen(sPort);
i = 0;
while (i<180)
   A = fgets(sPort);
   B = fgets(sPort);
   num2(i) = str2num(B);
   i = i+1;
end
fclose(sPort);
delete(sPort);
j = 0;
unit = 1;
while j<180
    tab1(j,1) = (j)*unit
    tab1(j,2) = num1(j)
    tab1(j,3) = num1(j)*cosd((j)*unit)
    tab1(j,4) = num1(j)*sind((j)*unit)
    tab2(j,1) = (j)*unit
    tab2(j,2) = num2(j)
    tab2(j,3) = num2(j)*cosd((j)*unit)
    tab2(j,4) = num2(j)*sind((j)*unit)
    j = j+1
end
plot(tab1(:,3),tab1(:,4))
plot(tab2(:,3),tab2(:,4))
Asking questions about your bicycle at a car dealer is usually pointless. Why are you asking about Matlab here?
