Arduino and midi project help
How do I set up and code arduino to except a midi signal to turn on/off different relays according to different midi cc commands?
Did you do any research at all?
const uint8_t CONTROL_CHANGE = 0xB;
struct MIDI_message {
  union {
    struct {
      uint8_t channel : 4;
      uint8_t message_type : 4;
    uint8_t status;
  uint8_t data1;
  uint8_t data2;
bool receiveMIDI(Stream &s, MIDI_message &m) { // Receives 3-Byte MIDI messages
  static uint8_t header = 0;
  static uint8_t data1 = 0b10000000;
  if (!s.available())
    return false;
  uint8_t newByte = s.read();
  if (newByte & 0b10000000) {   // Header byte received
    header = newByte;
    return false;
  if (header & 0b10000000) {
    if (data1 == 0b10000000) {  // First data byte received
      data1 = newByte;
      return false;
    m.status = header;          // Second data byte received
    m.data1 = data1;
    m.data2 = newByte;
    data1 = 0b10000000;
    return true;
  return false;                 // Data byte without header received
  Serial.begin(31250);
  MIDI_message midimsg;
  if (receiveMIDI(Serial, midimsg)) {
    if (midimsg.message_type == CONTROL_CHANGE) {
       * Don't print ASCII to a MIDI device, obviously,
       * just for demonstration purposes.
      Serial.print("Received MIDI Control Change message on channel ");
      Serial.print(midimsg.channel + 1);
      Serial.print(", controller #");
      Serial.print(midimsg.data1);
      Serial.print(", value = ");
      Serial.println(midimsg.data2);
Pieter
