Arduino and Motor shield power problems
Hi everyone,
I need some assistant with the Arduino Mega and motor shield. I am having a problem with the GM9 motor, I used the basic code to test the motors. It seems that they will not work. Here is the code I used:
int motor_reset = 2; //digital pin 2 assigned to motor reset
pinMode(motor_reset, OUTPUT);
digitalWrite(motor_reset, LOW);
delay(50);
digitalWrite(motor_reset, HIGH);
delay(50);
//select the function you want to use but ensure two are not running simultaneously.
//motorforward();
//motorreverse();
//rotateccw();
//motorstop();
//subroutine motor forward
void motorforward()
//left motor
unsigned char buff1[6];
buff1[0]=0x80; //start byte - do not change
buff1[1]=0x00; //Device type byte – do not change
buff1[2]=0x01; //Motor number and direction byte; motor one =00,01
buff1[3]=0x45; //Motor speed "0 to 128" in hex (ex 100 is 64 in hex)
for(int i=0; i<4; i++) {Serial.print(buff1*, BYTE);}*
//right motor
unsigned char buff2[6];
buff2[0]=0x80;
buff2[1]=0x00;
buff2[2]=0x03; //Motor number and direction byte; motor two=02,03
buff2[3]=0x45;
for(int i=0; i<4; i++) {Serial.print(buff2*, BYTE);}*
//subroutine reverse at half speed
void motorreverse()
//left motor
unsigned char buff3[6];
buff3[0]=0x80;
buff3[1]=0x00;
buff3[2]=0x00;
buff3[3]=0x35;
for(int i=0; i<4; i++) {Serial.print(buff3*, BYTE);}*
//right motor
unsigned char buff4[6];
buff4[0]=0x80;
buff4[1]=0x00;
buff4[2]=0x02;
buff4[3]=0x35;
for(int i=0; i<4; i++) {Serial.print(buff4*, BYTE);}*
//Motor all stop
void motorstop()
//left motor
buff3[0]=0x80;
buff3[1]=0x00;
buff3[2]=0x00;
buff3[3]=0x00;
//right motor
buff4[0]=0x80;
buff4[1]=0x00;
buff4[2]=0x02;
buff4[3]=0x00;
void rotateccw()
//left motor
buff1[0]=0x80;
buff1[1]=0x00;
buff1[2]=0x01;
buff1[3]=0x40;
//right motor
buff2[0]=0x80;
buff2[1]=0x00;
buff2[2]=0x02;
buff2[3]=0x40;
I am wonder if there is not enough power to turn on the motor. Please help.
