Arduino and MPU dont work properly when not connected to laptop
I have a microcontroller connected to a gyroscope and an active buzzer. Once the angle in the Z direction crosses 45 degrees, the arduino makes the buzzer beep. This code works fine when the arduino is connected to the laptop, I can read the angle, acceleration and velocity values.
When I disconnect the arduino from the laptop and instead provide power through a battery, the code doesnt work exactly right. Here is what I mean by this, the code does make the buzzer beep, it pretty much does everything that doesnt include or is not dependent by the gyroscope. But when I ask for it to make the buzzer beep ONLY when angle > 45, it fails. This would mean that something is wrong with the gyroscope, but when I switch back to the laptop, the gyro works perfectly. I assume the gyro or microcontroller are not reading acceleration and velocity when connected to the battery but I have no way to check since I dont have a display on this circuit.
Does anyone know whats going on? Is this a hardware, electrical or coding problem? What is happening between the laptop to battery switch that is making the gyroscope act wierd?
Welcome! I am not sure but it sounds like a hardware problem. The best way to get an answer is to post an annotated schematic showing ll connections, power, ground and power sources.
