arduino and mysql connection
Hello :relaxed: ,
i am trying to send data to mySql database.
therfore i use the program bellow.
but i don t know how to alter some lines.
the problem is that i connect my arduino uno with official wifi shield to a hotspot on a notebook(win7). also on this notebook i run the mysql database.
i have no clue what i have to type in the line for char server[]=....???
i suggest the ip of my laptop right?
next problem is in line for the port. i chose 80, the port for apache. or has there to be the port of mysql?
last question is how i write the right directory for php?
i think client.println("POST localhost/insert_mysql.php HTTP/1.1");
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "hotspot";
char password[] = "12345678";
int status = WL_IDLE_STATUS;
WiFiClient client;
// EDIT: 'Server' address to match your domain
char server[] = "178.202.228.171"; // This could also be 192.168.1.18/~me if you are running a server on your computer on a local network.
// This is the data that will be passed into your POST and matches your mysql column
int yourarduinodata = 999;
String yourdatacolumn = "yourdata=";
String yourdata;
  connectWifi();
  // You're connected now, so print out the status
  printWifiStatus();
  postData();
void connectWifi() {
  // Attempt to connect to wifi network
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, password);
    // Wait 10 seconds for connection
    Serial.print("Connection succesful!");
    delay(10000);
void printWifiStatus() {
  // Print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // Print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // Print the received signal strength
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
// This method makes a HTTP connection to the server and POSTs data
void postData() {
  // Combine yourdatacolumn header (yourdata=) with the data recorded from your arduino
  // (yourarduinodata) and package them into the String yourdata which is what will be
  // sent in your POST request
  yourdata = yourdatacolumn + yourarduinodata;
  // If there's a successful connection, send the HTTP POST request
  if (client.connect(server, 80)) {  //What Port do i have to choose?
    Serial.println("connecting...");
    // EDIT: The POST 'URL' to the location of your insert_mysql.php on your web-host
    client.println("POST /insert_mysql.php HTTP/1.1");
    // EDIT: 'Host' to match your domain
    client.println("Host: www.yourdomain.com");
    client.println("User-Agent: Arduino/1.0");
    client.println("Connection: close");
    client.println("Content-Type: application/x-www-form-urlencoded;");
    client.print("Content-Length: ");
    client.println(yourdata.length());
    client.println();
    client.println(yourdata);
  else {
    // If you couldn't make a connection:
    Serial.println("Connection failed");
    Serial.println("Disconnecting.");
    client.stop();
Yes.
String yourdata;
Wasteful. Learn to use strings (NULL terminated arrays of chars) instead.
Unless your PC is hosting multiple domains (highly unlikely), you don't need the Host line. You don't need the User-agent line. The default for the Connection attribute is close, so that is useless. Using a GET request is far simpler. None of the rest of that stuff would be needed.
Are you trying to execute a script by making a GET/PUT/POST request, or are you trying to talk directly to MySQL? Looks like a POST request, but should/could be a GET request, to me. So, the httpd port is correct.
You think wrong. Localhost means the machine that is making the GET request. I'm nearly certain that you have NOT ported PHP to the Arduino.
You defined a directory where the stuff to be executed goes. When I did it, I set C:\Apache24\htdocs as the root directory. To execute a script that lives in that directory:
GET scriptName.ext HTTP/1.1
Or POST, if you must.
If you create a directory in the root directory, like uselessStuff, that contains thisIsCrap.php.
GET uselessStuff/thisIsCrap.php?name=value&anotherName=anotherValue HTTP/11
