Hi!
I have a couple of issues with my neopixel strip. I ordered a 5m strip and cut it up. Now I have 2 smaller parts (about 60 neopixels in total) that I soldered together with a cable. (Plus to plus, minus to minus and data to data. The arduino sends the data for the strip via pin 6, everything works fine, at least for the first part.
The arduino is programmed in such a way that when it is connected to the a power source it sends a pulse to the strip: color blue. The first part also takes on this color, but the second part, which is connected to the first with cables, remains off. With my tension meter I saw that there is tension on the second part as well. I.e. these cables need to transfer the power. However, it does not transmit the data ... I ordered new cables yesterday in the hope that it would work with them. It didn't work even though they were specially made for it. The cables are normally soldered to the two parts.
Info: When I connect the power to the other part, it lights up. So neither of the two parts is broken. It must have something to do with the cable, the solder or the software.
My current cables: https://www.amazon.de/gp/product/B07JG3SD43/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
My previous cables: https://www.amazon.de/gp/product/B07TGKPFHK/ref=ppx_yo_dt_b_asin_image_o09_s00?ie=UTF8&psc=1
My neopixels: https://www.amazon.de/gp/product/B01CDTEJBG/ref=ppx_yo_dt_b_asin_image_o02_s00?ie=UTF8&psc=1
Here is my code:
int LED_COUNT = 60;
Adafruit_NeoPixel strip (LED_COUNT, 6, NEO_RGB + NEO_KHZ800);
void setup () {
strip.begin ();
strip.fill (strip.Color (0, 0, 20), 0, LED_COUNT);
strip.show ();
Many thanks for your help.
Regards
Colin Schneider
