arduino and pc
can i use arduino to start the pc and run processing sketch file after that???
Sure. Connect a servo to the Arduino. Position it so that when the Arduino rotates the servo, it presses the on button.
No. The Arduino can not start a process on the PC.
eng_house:
Sure, you only need to short the two power wires to start the computer up, and then just put a processing sketch thats been exported (or a shortcut to said program) in the the startup folder and it will auto run.
P.S I don't recommend messing around with your computer unless you know what you are doing..
