any one have coded protocol for linking an Arduino with the ppJoy virtual joystick Yahoo | Mail, Weather, Search, Politics, News, Finance, Sports & Videos ???
I'm looking a way to using arduino as joystick interface in windows and it seam that this is an good startup to deal with :
we can input serial data in ppjoy with com port or use the ppm pulse and create a virtual joystick from arduino. I don't know really the byte order for now but if someone as an idea about it ....
I think there was some code posted on a thread somewhere here a while ago for generating multichannel PPM signal that should be suitable for driving ppjoy.
If you can't find anything, let me know and I will try and dust off some old code using timer1 to generate pulses that simulated the 'training port' output of a six channel transmitter.
i have found this information on the web from man who made an interface for ppjpy....2log.de
One of the ppjoy HMS protocol is from tis type :
One byte with 0xF0 + a number of channel (for synchro)
and channel byte maped between 0x00 and 0xEF
at the baudrat of 9600 with first channel reserved for 0x00
exemple for 6 channel : 0xF6 0x00 0xF8 0xF8 0xF8 0xF8 0xF8 0xF6 ....ect
and an auther is at 19200 baud :
Sync Byte which is constant 0xFF plus as many bytes that map the transmitters channels between 0x00 and 0xFE
exemple : 0xFF 0xF8 0xF8 0xF8 0xF8 0xF8 0xFF 0xF8.....ect
for 5 channel.
so, for the first metod i writing this code :
#define joyPin 2
void setup(){
pinMode(joyPin,INPUT);
void loop(){
int joyYvalue=analogRead(joyPin);
joyYvalue/=2;
thanks for the tip.
but nothing to do with the ppjoy pbm....
i think about that delay between bytes packet can do a pbm for the sync....what do you thinc about ?
it's a pause...then the bytes pack...then pause...ans so fort...
Serial Protocol Used
The serial output is at 9600 baud, 8 data bits, No parity and 1 stop bit. The first character will be in the range 241 to 248 decimal, this is made up from 240 + the number of pulses measured. The second character contains the status of 4 push buttons that can be connected to the interface unit. The third to last (max 16) characters contain the values of the control channel pulses. Decimal 100 = 1mS, 200 = 2mS.
This implies you need to send an additional byte after the synch, try it and see if that helps.
Any luck with this? I'm just starting to think about how to make a joystick device for the mac based on arduino output and wondering if your approach above might work - though obviously the windows app won't do it
To connect with PPJoy via the COM port your arduino is attached to, make sure that you are operating a 9600 baud, AND that each of your serial.print statements are in the format serial.print(data,BYTE);
including BYTE makes sure that each statement sends 1 byte instead of changing the format to human readable type. It struck me while browsing the examples and finding ASCII Table, and noticing the BYTE included in the print statements for the char data.
Using FMS PIC 9600 baud (Generic):
Serial.print(241,BYTE); //sync byte, as on the website this is 240 + 1 because i will read one channel
Serial.print(0,BYTE); //Button states, zero meaning no buttons pressed
Serial.print(joystick_axis,BYTE); //joystick_axis would be a variable, likely given by analogRead
Did you try ClydeSha's code to see if that works. If that works for you then look at what needs to be sent for the number of channels you have. If Clyde's code doesn't work for you then you can look at your serial connectivity or PPJoy configuration.
i mean that in the game controller menu in windows, the pointer of the joystick moves upwards (if i move the joystick up) but it's glitchy and the pointer suddenly moves left or right but then moves back up.
i remembered that i read somewhere that the original gameport has 128 steps per axis (0 - 127) but the analog in on the arduino has 1024 steps (0 - 1023) so a simple calculation was made, divide it by 8!
in a few days you'll see my whole code and pics on the exhibition page
Hey there! I'm having some troubles with the interface of two potenciometers. I'm trying to use this pots to do some kind of a steering wheel, well, it kinda works..... but only with one pot, if I hook up another one, THE DISASTER!!!!!! it starts giving me odd results..... I'm using one of the codes you guys uploaded....
byte x = 0;
int x_pin = 0;
pinMode(x_pin, INPUT);
x = analogRead(x_pin) / 4;
Serial.print(x,BYTE);
As u can see, i've removed the y axis, cuz was giving me problems. This code works perfect, and if u divide the analogRead by 8 then u get a better read for a trhottle. Dividing it by 4 is better for a wheel. Now, how do I get the arduino to send to the PPJOY a signal so I can use 'X' number of joysticks????
