Arduino and Processing communication
I have read all of the examples, for some reason Processing is unable to read my analog pins from Arduino. I can see plenty of data being written to the usb serial port, but values are always read as 0 in processing.
Can you see anything wrong with the below?
Thanks,
Aaron.
Arduino code:
#include <Boards.h>
#include <Firmata.h>
#include <FirmataConstants.h>
#include <FirmataDefines.h>
#include <FirmataMarshaller.h>
#include <FirmataParser.h>
#define red 8
#define green 9
#define blue 10
#define POT1 A0    // The potentiometer is connected to analog pin 0
#define POT2 A1    // The potentiometer is connected to analog pin 0
#define POT3 A2
int pot1Value = 0, pot2Value = 0, pot3Value = 0;
byte redValue, greenValue, blueValue = 0;
// the setup routine runs once when you press reset:
  // declare pin 9 to be an output:
  pinMode(red, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(blue, OUTPUT);
  Firmata.setFirmwareVersion(FIRMATA_FIRMWARE_MAJOR_VERSION, FIRMATA_FIRMWARE_MINOR_VERSION);
  Firmata.printVersion();
  Firmata.begin(57600);
// the loop routine runs over and over again forever:
  // set the  brightness of pin 9:
  pot1Value = analogRead(POT1);
  pot2Value = analogRead(POT2);
  pot3Value = analogRead(POT3);
  redValue = (int) map(pot1Value, 0, 1023, 0, 255);
  greenValue = (int) map(pot2Value, 0, 1023, 0, 255);
  blueValue =  (int) map(pot3Value, 0, 1023, 0, 255);
  analogWrite(red, redValue);
  analogWrite(green, greenValue);
  analogWrite(blue, blueValue);
  Firmata.sendAnalog(POT1, pot1Value);
  Firmata.sendAnalog(POT2, pot2Value);
  Firmata.sendAnalog(POT3, pot3Value);
Processing code
import org.firmata.*;
import controlP5.*;
import processing.serial.*;
import cc.arduino.*;
ControlP5 cp5;
Knob ledbrightness;
Serial usbPort;
Arduino arduino;
String port;
// Arduino pots
static final int POT1 = 0;
static final int POT2 = 1;
static final int POT3 = 2;
int r, g, b = 0;
int pot1Value, pot2Value, pot3Value, prevPot1Value, prevPot2Value, prevPot3Value = 0;
color ledColor = color(0, 0, 0);
  size(700, 400);
  smooth();
  noStroke();
  for (String port : Serial.list()) {
    if (port.contains("cu.usb")) {
      println(port);
      arduino = new Arduino(this, port, 57600);
  cp5 = new ControlP5(this);
  ledbrightness = cp5.addKnob("ledbrightness")
    .setRange(0, 255)
    .setValue(50)
    .setPosition(100, 70)
    .setRadius(50)
    .setDragDirection(Knob.VERTICAL);
void draw() {
  mapPotsToColor();
  background(ledColor);
void mapPotsToColor() {
  pot1Value = arduino.analogRead(POT1);
  pot2Value = arduino.analogRead(POT2);
  pot3Value = arduino.analogRead(POT3);
  println(new Object[] {pot1Value, pot2Value, pot3Value});
  if (pot1Value != prevPot2Value || pot2Value != prevPot2Value || pot3Value != prevPot3Value) {
    r = (int)map(pot1Value, 0, 1023, 0, 255);
    g = (int)map(pot2Value, 0, 1023, 0, 255);
    b = (int)map(pot3Value, 0, 1023, 0, 255);
    ledColor = color(r, g, b);
    prevPot1Value = pot1Value;
    prevPot2Value = pot2Value;
    prevPot3Value = pot3Value;
void ledbrightness(int theValue) {
  println("a knob event. setting background to "+theValue);
  ledColor = color(theValue, 0, 0);
The Processing sketch expects the standard Firmata sketch to be installed on the Arduino - not that mess you actually installed.
