i have a problem with arduino and processing serial. when i loaded the code for arduino in the mega board, the servo was set to 90 degrees and this worked fine. However, then i ran processing code, the rx led flashed which looked right but the servo wont work as it supposed to.
arduino code:
#include <Servo.h>
Servo servo;
int pos=90;
servo.attach(8);
servo.write(90);
Serial.begin (9600);
if (Serial.available()>0)
byte input = Serial.read();
if (input == 'L')
servo.write (pos--);
else if (input == 'R')
servo.write(pos++);
processing code:
import processing.serial.*;
Serial port;
size(50,50);
port = new Serial (this, "COM3",9600);
delay(300);
void draw()
if (keyPressed)
if (key == CODED)
if (keyCode == LEFT && keyCode != RIGHT)
port.write ('L');
println("L");
delay(30);
if (keyCode == RIGHT && keyCode != LEFT)
port.write('R');
println("R");
delay(30);
port.write('c');
println("c");
delay(30);
all of these work fine if i use firmata. But i want to use PID controller library in arduino. thats why i chose to do it this way
