Arduino and relay
Hi all, i want to switch a relay with the arduino UNO, but i wont switch far enough to make or break a contact. When i connect the relais directly to 5v (power pin) and gnd i worked. Relais info: JQX-14FC-2C (6vdc) I tryed the digital pins 13,12,11 and 10. And of course GND
And yes i connected it the right way.
int led = 10;
 pinMode(led, OUTPUT);
  digitalWrite(led, HIGH)
Any ideas?
you are overloading to pin. make I/Opin control a transistior..that controls the relays coil.
Odd because there is no "right way round" to connect a coil. As well as a transistor you need a diode across the coil.
So those are the pins you have damaged then.
