Arduino and sensor
hello’ i’m just asking on how to display live sensor reading in nokia 5110… i’m using arduino nano, pulse sensor and lsm9ds0… and this is my code… an error message is “invalid conversion from int to char” thanks for the reply… :slight_smile: :slight_smile: :slight_smile:
#include <SPI.h> // We'll use SPI to transfer data. Faster!
#define PIN_SCE   11
#define PIN_RESET 12
#define PIN_DC    10
#define PIN_SDIN  9
#define PIN_SCLK  8
#define PIN_LCD   7 // backlight
#define LCD_C LOW
#define LCD_D HIGH
#define LCD_COMMAND  0
#define LCD_X 84
#define LCD_Y 48
//  VARIABLES
int pulsePin = 0;                 // Pulse Sensor purple wire connected to analog pin 0
int blinkPin = 13;                // pin to blink led at each beat
int fadePin = 5;                  // pin to do fancy classy fading blink at each beat
int fadeRate = 0;                 // used to fade LED on with PWM on fadePin
char strBuffer[30];
int txtCyclesMax = 20;
int txtCyclesCur = 0;
// these variables are volatile because they are used during the interrupt service routine!
volatile int BPM;                   // used to hold the pulse rate
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // holds the time between beats, the Inter-Beat Interval
volatile boolean Pulse = false;     // true when pulse wave is high, false when it's low
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
// The following is needed to create text boxes!
static const byte ASCII[][5] =
  {0x00, 0x00, 0x00, 0x00, 0x00} // 20
  , {0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0
  , {0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1
  , {0x42, 0x61, 0x51, 0x49, 0x46} // 32 2
  , {0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3
  , {0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4
  , {0x27, 0x45, 0x45, 0x45, 0x39} // 35 5
  , {0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6
  , {0x01, 0x71, 0x09, 0x05, 0x03} // 37 7
  , {0x36, 0x49, 0x49, 0x49, 0x36} // 38 8
  , {0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9
  , {0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
  , {0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
  , {0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
  , {0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
  , {0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
  , {0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
  , {0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
  , {0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
  , {0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
  , {0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J
  , {0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K
  , {0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L
  , {0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M
  , {0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N
  , {0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O
  , {0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P
  , {0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q
  , {0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R
  , {0x46, 0x49, 0x49, 0x49, 0x31} // 53 S
  , {0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T
  , {0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U
  , {0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V
  , {0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W
  , {0x63, 0x14, 0x08, 0x14, 0x63} // 58 X
  , {0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y
  , {0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z
  , {0x20, 0x54, 0x54, 0x54, 0x78} // 61 a
  , {0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b
  , {0x38, 0x44, 0x44, 0x44, 0x20} // 63 c
  , {0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d
  , {0x38, 0x54, 0x54, 0x54, 0x18} // 65 e
  , {0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f
  , {0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g
  , {0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h
  , {0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i
  , {0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j
  , {0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k
  , {0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l
  , {0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m
  , {0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n
  , {0x38, 0x44, 0x44, 0x44, 0x38} // 6f o
  , {0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p
  , {0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q
  , {0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r
  , {0x48, 0x54, 0x54, 0x54, 0x20} // 73 s
  , {0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t
  , {0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u
  , {0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v
  , {0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w
  , {0x44, 0x28, 0x10, 0x28, 0x44} // 78 x
  , {0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y
  , {0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z
// Writes a character
void LcdCharacter(char character)
  LcdWrite(LCD_D, 0x00);
  for (int index = 0; index < 5; index++)
    LcdWrite(LCD_D, ASCII[character - 0x20][index]);
// Clears the screen
void LcdClear(void)
  for (int index = 0; index < LCD_X * LCD_Y / 8; index++)
void LcdWriteData(byte dat)
  digitalWrite(PIN_DC, HIGH);
  digitalWrite(PIN_SCE, LOW);
  shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, dat);
  digitalWrite(PIN_SCE, HIGH);
void LcdWriteCmd(byte cmd)
  digitalWrite(PIN_DC, LOW);
  shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, cmd);
void LcdXY(int x, int y)
  LcdWriteCmd(0x80 | x); //Column
  LcdWriteCmd(0x40 | y); // Row
// Initializes the Nokia 5110
void LcdInitialise(void)
  pinMode(PIN_SCE, OUTPUT);
  pinMode(PIN_RESET, OUTPUT);
  pinMode(PIN_DC, OUTPUT);
  pinMode(PIN_SDIN, OUTPUT);
  pinMode(PIN_SCLK, OUTPUT);
  pinMode(PIN_LCD, OUTPUT);
  digitalWrite(PIN_LCD, HIGH);
  digitalWrite(PIN_RESET, LOW);
  digitalWrite(PIN_RESET, HIGH);
  LcdWrite(LCD_C, 0x21 );  // LCD Extended Commands.
  LcdWrite(LCD_C, 0xB1 );  // Set LCD Vop (Contrast).
  LcdWrite(LCD_C, 0x04 );  // Set Temp coefficent. //0x04
  LcdWrite(LCD_C, 0x15 );  // LCD bias mode 1:48. //0x13
  LcdWrite(LCD_C, 0x0C );  // LCD in normal mode.
  LcdWrite(LCD_C, 0x20 );
// Creates a full text string
void LcdWriteString(char *characters)
  while (*characters)
    LcdCharacter(*characters++);
/*void LcdWriteCharacter(char character)
  for (int i=0; i<5; i++) LcdWriteData(ASCII[character - 0x20][i];
  LcdWriteData(0x00);
// Sends data to the display
void LcdWrite(char dc, char data)
  digitalWrite(PIN_DC, dc);
  shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data);
  pinMode(blinkPin, OUTPUT);        // pin that will blink to your heartbeat!
  pinMode(fadePin, OUTPUT);         // pin that will fade to your heartbeat!
  Serial.begin(115200);             // we agree to talk fast!
  interruptSetup();                 // sets up to read Pulse Sensor signal every 15s
  LcdInitialise();
  LcdClear();
//charstring[8];
char BPM[6]; // msg must be large enough to hold the entire float + decimal
// Converts float to ints, and copies to msg for putting on the air
void sensorBPM (double value) {
  int t100 = 100 * value;
  int tWhole = t100 / 100;
  int tFract = t100 % 100;
  sprintf(BPM, "%d.%d", tWhole, tFract < 10 ? 0 : tFract);
  sendDataToProcessing('S', Signal);     // send Processing the raw Pulse Sensor data
  if (QS == true) {                      // Quantified Self flag is true when arduino finds a heartbeat
    fadeRate = 255;                  // Set 'fadeRate' Variable to 255 to fade LED with pulse
    sendDataToProcessing('B', sensorBPM);  // send heart rate with a 'B' prefix
    sendDataToProcessing('Q', IBI);  // send time between beats with a 'Q' prefix
    QS = false;             // reset the Quantified Self flag for next time
    Serial.println(sensorBPM);
      if (BPM < 60)
       LcdWriteString("Heart rate: ");
        LcdWriteString(sensorBPM);
        LcdWriteString("Low Heartbeat");
      else if (BPM >130)
      LcdWriteString("No Heartbeat");
        else if (BPM > 100)
        LcdWriteString("High Heartbeat");
   else if (BPM <= 100)
        LcdWriteString("Normal Heartbeat");
  ledFadeToBeat();
  delay(20);                             //  take a break
void ledFadeToBeat() {
  fadeRate -= 15;                         //  set LED fade value
  fadeRate = constrain(fadeRate, 0, 255); //  keep LED fade value from going into negative numbers!
  analogWrite(fadePin, fadeRate);         //  fade LED
void sendDataToProcessing(char symbol, int data ) {
  Serial.print(symbol);                // symbol prefix tells Processing what type of data is coming
  Serial.println(data);                // the data to send culminating in a carriage return
I attempted to compile the code using my IDE (1.04). There are more errors than the one you mention. The first that comes up is that interruptSetup(); is not declared or defined. Then you have 2 BPM variables, one is a scalar and the other an array. You can't use the same name for both. Need to fix those errors first then re-verify and go from there.
When posting errors, please post the entire error. The error report will include the line number and that makes it easier to find where the error is instead of digging through all the code to try to find it.
this is the code in the attachment…
Interrupt.ino (5.59 KB)
PulseSensorAmped_Arduino_1dot1.ino (9.14 KB)
I will not download code. Post the code like you did in the first post.
this is the code for interrupt,
volatile int rate[10];                    // used to hold last ten IBI values
volatile unsigned long sampleCounter = 0;          // used to determine pulse timing
volatile unsigned long lastBeatTime = 0;           // used to find the inter beat interval
volatile int P =512;                      // used to find peak in pulse wave
volatile int T = 512;                     // used to find trough in pulse wave
volatile int thresh = 512;                // used to find instant moment of heart beat
volatile int amp = 100;                   // used to hold amplitude of pulse waveform
volatile boolean firstBeat = true;        // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = true;       // used to seed rate array so we startup with reasonable BPM
void interruptSetup(){
  // Initializes Timer2 to throw an interrupt every 2mS.
  TCCR2A = 0x02;     // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
  TCCR2B = 0x06;     // DON'T FORCE COMPARE, 256 PRESCALER
  OCR2A = 0X7C;      // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
  TIMSK2 = 0x02;     // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
  sei();             // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
// THIS IS THE TIMER 2 INTERRUPT SERVICE ROUTINE.
// Timer 2 makes sure that we take a reading every 2 miliseconds
ISR(TIMER2_COMPA_vect){                         // triggered when Timer2 counts to 124
    cli();                                      // disable interrupts while we do this
    Signal = analogRead(pulsePin);              // read the Pulse Sensor
    sampleCounter += 1500;                         // keep track of the time in mS with this variable
    int N = sampleCounter - lastBeatTime;       // monitor the time since the last beat to avoid noise
//  find the peak and trough of the pulse wave
    if(Signal < thresh && N > (IBI/5)*3){       // avoid dichrotic noise by waiting 3/5 of last IBI
        if (Signal < T){                        // T is the trough
            T = Signal;                         // keep track of lowest point in pulse wave
    if(Signal > thresh && Signal > P){          // thresh condition helps avoid noise
        P = Signal;                             // P is the peak
       }                                        // keep track of highest point in pulse wave
  //  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
  // signal surges up in value every time there is a pulse
if (N > 250){                                   // avoid high frequency noise
  if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) ){
    Pulse = true;                               // set the Pulse flag when we think there is a pulse
    digitalWrite(blinkPin,HIGH);                // turn on pin 13 LED
    IBI = sampleCounter - lastBeatTime;         // measure time between beats in mS
    lastBeatTime = sampleCounter;               // keep track of time for next pulse
         if(firstBeat){                         // if it's the first time we found a beat, if firstBeat == TRUE
             firstBeat = false;                 // clear firstBeat flag
             return;                            // IBI value is unreliable so discard it
         if(secondBeat){                        // if this is the second beat, if secondBeat == TRUE
            secondBeat = false;                 // clear secondBeat flag
               for(int i=0; i<=9; i++){         // seed the running total to get a realisitic BPM at startup
                    rate[i] = IBI;
    // keep a running total of the last 10 IBI values
    word runningTotal = 0;                   // clear the runningTotal variable
    for(int i=0; i<=8; i++){                // shift data in the rate array
          rate[i] = rate[i+1];              // and drop the oldest IBI value
          runningTotal += rate[i];          // add up the 9 oldest IBI values
    rate[9] = IBI;                          // add the latest IBI to the rate array
    runningTotal += rate[9];                // add the latest IBI to runningTotal
    runningTotal /= 10;                     // average the last 10 IBI values
    BPM = 60000/runningTotal;               // how many beats can fit into a minute? that's BPM!
    QS = true;                              // set Quantified Self flag
    // QS FLAG IS NOT CLEARED INSIDE THIS ISR
  if (Signal < thresh && Pulse == true){     // when the values are going down, the beat is over
      digitalWrite(blinkPin,LOW);            // turn off pin 13 LED
      Pulse = false;                         // reset the Pulse flag so we can do it again
      amp = P - T;                           // get amplitude of the pulse wave
      thresh = amp/2 + T;                    // set thresh at 50% of the amplitude
      P = thresh;                            // reset these for next time
      T = thresh;
  if (N > 2500){                             // if 2.5 seconds go by without a beat
      thresh = 512;                          // set thresh default
      P = 512;                               // set P default
      T = 512;                               // set T default
      lastBeatTime = sampleCounter;          // bring the lastBeatTime up to date
      firstBeat = true;                      // set these to avoid noise
      secondBeat = true;                     // when we get the heartbeat back
  sei();                                     // enable interrupts when youre done!
}// end isr
I put the interrupt setup code in a new tab and that error is gone. Now work on the BPM declared twice error.
sketch_jul11a:206: error: conflicting declaration 'char BPM [6]' sketch_jul11a:28: error: 'BPM' has a previous declaration as 'volatile int BPM'
You need to change the name of one of them.
There are a lot more errors, but you need to address them from the top down as one error can generate many more.
thank you for your response.. may I ask, how to display the sensor reading because I encountered an error that say's "invalid conversion from int to char"
From reply #1
See reply 5 for posted error.
