Arduino and serial POS Printer
Hello,
I would like to connect my Arduino to an POS thermal printer with serial cable, I tried with only RX, TX and GND, It work but the printer print weird characters !! it's because I not used MAX323 converter ?
If so, it's not complicated to make it?
Thank you
it’s because I not used MAX323 converter
Quite possibly, but without data on the device who knows?
I am sorry, I don’t understand
kiman26:
I am sorry, I don't understand
You are the ONLY one who can see what kind of POS (piece of sh*t?) printer you want to connect to the Arduino. Is it too difficult to understand that you need to share that information?
You should post a link to the datasheet for the printer you want to use.
If it uses RS232 voltage levels you need to use a MAX232 converter to protect your Arduino from damage and to make sure that communication happens.
It may also be that the printer has a choice of character sets and you have not chosen the appropriate one.
...R
You can verify it in the commands manual of the printer, “attached in this post”
I used these code :
#include <SoftwareSerial.h>
SoftwareSerial myserial(10, 11); // RX, TX
 myserial.print(27);
 myserial.print(75));
 myserial.print(1);
Thank you for your help
578-772000000011_1.50.pdf (1.14 MB)
That is a very long document (I hope you have read it carefully - seriously) but it is only part of the story. You also need to post a link to the document about the hardware connection.
...R
Using a SoftwareSerial instance without having called begin() is pointless.
oh sorry, here is my code:
SoftwareSerial Thermal(10, 11); // RX, TX
//le bouton est connecté à la broche 2 de la carte Adruino
const
int led = 7;
int bouton = 4;
int etatBouton;
int ESC = 27;
int CMD1 = 75;
int ON = 1;
pinMode(led, OUTPUT);
pinMode(bouton, INPUT);
etatBouton = HIGH;
digitalWrite(led,LOW);
digitalWrite(bouton,HIGH);
initPrinter();
void initPrinter()
 Thermal.begin(115200); // to write to our new printer
 Thermal.print(ESC);
 Thermal.print("@");
etatBouton = digitalRead(bouton);
if (etatBouton == HIGH) //test si le bouton est OFF
    else  //test si le bouton est OFF (donc BAS)
      //set speed
 Thermal.write(27);
 Thermal.write(120);
 Thermal.write(1);
//Print
 Thermal.write("TEST PRINT");
 Thermal.write(10);
 //Print
 Thermal.write(27);
 Thermal.write(100);
 Thermal.write(1);
 //cutting
 Thermal.print(27);
 Thermal.write(105);
    digitalWrite(led,HIGH);
Start testing with a more realistic 9600 baud. SoftwareSerial is slow.
If you need 115200 baud then you need a Mega, Leonardo or Micro with a spare HardwareSerial port.
...R
The default speed of the printer is 115200, and Yes I make this test with mega.
kiman26:
Trying to program this printer without reading the technical hardware manual is also pointless.
You think I try to program the printer without read the technical hardware manual ?
kiman26:
There is not much evidence in this Thread that you have done so. For example, I have seen nothing like
"It says xxxx in the manual on page YYY and I don't understand if that means I should do A or B"
And we are still waiting for you to post a link to it.
...R
 Thermal.print(ESC);
 Thermal.write(27);
 Thermal.write(120);
 Thermal.write(1);
You really need to understand the difference between print() and write() and when to use each.
What are the 4 hardware serial ports doing, then?
It's not work with all 4 hardware serial in mega :(.
But after I used max232 chip it working now.
Thank you
