You’re using the 5V regulator on the L298 module to power a Nano, display, and a servo after dropping 4 volts? I believe that regulator is only meant for logic (signal) level currents, not the 1000 mA one servo might draw. You might put a fan on it and good luck.
BTW: Don’t you need a ground wire from the motor driver to Nano GND?
outsider:
BTW: Don't you need a ground wire from the motor driver to Nano GND?
yes, sorry - i didn't indicate that on the diagram.
outsider:
You're using the 5V regulator on the L298 module to power a Nano, display, and a servo after dropping 4 volts? I believe that regulator is only meant for logic (signal) level currents, not the 1000 mA one servo might draw.
i guess one can say that - for me, it's measuring the power rail - i suppose that also means "powering that (measuring) device" - i am assuming (wrongly ??) that would take insignificant current draw ? (relative to the other devices)
outsider:
i'm asking for Best Practice - how SHOULD it be done properly ?
