I’ve got a Mega in a SERB robot. I’m using the serb test program (below), but the servos don’t seem to stop when they’re getting a stop from the program. At first I thought it was my servo mod, but a test program:
#include <Servo.h>
Servo myservo;
myservo.attach(9);
myservo.write(1500);
Confirms they’re pretty well centered.
I’m pretty new to this, so any hints would be greatly appreciated.
Here’s the SERB program…
- Arduino Controlled Servo Robot (SERB) - Test Program
- Behaviour: A simple test program which causes the SERB
- to turn randomly either left or right for a
- random time period between 0.1 and 1 second.
- The SERB will then drive forward for a random
- time period between 1 and 2 seconds. Finally
- pausing for 2 seconds before starting again.
- Wiring: Right Servo Signal - pin 9
- Left Servo Signal - pin 10
// START OF ARDUINO CONTROLLED SERVO ROBOT (SERB) PREAMBLE
#include <Servo.h>
#define LEFTSERVOPIN 10
#define RIGHTSERVOPIN 9
Servo leftServo;
Servo rightServo;
int speed = 100; //sets the speed of the robot (both servos) a percentage between 0 and 100
// END OF ARDUINO CONTROLLED SERVO ROBOT (SERB) PREAMBLE
- sets pins to appropriate states and attaches servos. Then pauses
- for 1 second before the program starts
serbSetup(); //sets the state of all neccesary pins and adds servos to your sketch
randomSeed(analogRead(0)); //sets the random number seed with something mildly random
- turns the robot either left or right (randomly) for a period between
- 0.1 and 1 second. Before going forward for a random time period
- between 1 and 4 seconds. Before pausing for two seconds then starting
- again.
turnRandom(100,1000); //Turns randomly left or right for a random time period between .1 second and one second
goForwardRandom(1000,2000); //Goes forward for a random time period between 1 and 2 seconds
goStop(); //Stops the robot
delay(2000); //pauses for 2 seconds (whilst stopped)
- turns the robot randomly left or right for a random time period between
- minTime (milliseconds) and maxTime (milliseconds)
void turnRandom(int minTime, int maxTime){
int choice = random(2); //Random number to decide between left (1) and right (0)
int turnTime = random(minTime,maxTime); //Random number for the pause time
if(choice == 1){ goLeft();} //If random number = 1 then turn left
else {goRight();} //If random number = 0 then turn right
delay(turnTime); //delay for random time
- goes forward for a random time period between minTime (milliseconds)
- and maxTime (milliseconds)
void goForwardRandom(int minTime, int maxTime){
int forwardTime = random(minTime,maxTime); //determine a random time to go forward
goForward(); //sets the SERB forward
delay(forwardTime); //delays for random time period
//START OF ARDUINO CONTROLLED SERVO ROBOT (SERB) ROUTINES
- sets up your arduino to address your SERB using the included routines
void serbSetup(){
setSpeed(speed);
pinMode(LEFTSERVOPIN, OUTPUT); //sets the left servo signal pin to output
pinMode(RIGHTSERVOPIN, OUTPUT); //sets the right servo signal pin to output
leftServo.attach(LEFTSERVOPIN); //attaches left servo
rightServo.attach(RIGHTSERVOPIN); //attaches right servo
goStop();
- sets the speed of the robot between 0-(stopped) and 100-(full speed)
- NOTE: speed will not change the current speed you must change speed
- then call one of the go methods before changes occur.
void setSpeed(int newSpeed){
if(newSpeed >= 100) {newSpeed = 100;} //if speed is greater than 100 make it 100
if(newSpeed <= 0) {newSpeed = 0;} //if speed is less than 0 make it 0
speed = newSpeed * 0.9; //scales the speed to be between 0 and 90
- sends the robot forwards
void goForward(){
leftServo.write(90 + speed);
rightServo.write(90 - speed);
- sends the robot backwards
void goBackward(){
leftServo.write(90 - speed);
rightServo.write(90 + speed);
- sends the robot right
void goRight(){
- sends the robot left
void goLeft(){
- stops the robot
void goStop(){
leftServo.write(90);
rightServo.write(90);
//END OF ARDUINO CONTROLLED SERVO ROBOT (SERB) ROUTINES
Thanks
Dave
