Arduino and Windows CE
I am thinking of connecting Arduino with a PNA Device running Windows CE through USB. I found a usb cable from an old camera with male USB type B from Arduino to male mini USB to PNA Device. All I want is to send messages through the serial port of Arduino in order to catch them from a program inside the PNA. Is this possible ? Do I have to make a special cable for the connection ? I read about installing FTDI Drivers to the device. Is this correct ?
Please help...
What's a PNA? When I had a windows CE device I was told I could only use the USB cable for tethering to a PC rather than actually making use of it.
But really, I only wanted to reply to say that you make lovely cigarrettes ;)
Thanks for the cigarettes but I only smoke them. ;)
A PNA device is like a PDA but running Windows CE 5.0 or 6.0
And what if you use IRDA for that...is easy!
Best Regards Frank
My device has only bluetooth. Do you think I can control arduino using bluetooth ? What shield do you recommend ? Any examples ?
Thanks.
