Recently I've purchased two xbee boards, both XB24's with function set XBEE 802.15.4-Version 10E6, a Duemilanove with an xbee sheild, and an xbee usb explorer. I've configured the xbee's through X-CTU and have typed and uploaded some simple Serial transmit code to the Arduino using the usb cable to check the communication between the (xbee + usb explorer) and the (arduino + xbee shield + xbee + usb cable)and it works. But all I'm able to do is view and watch the X-CTU terminal as a Serial debugger.
My question is: can I write code and upload it wirelessly to the arduino?-all the tutorials stop at this point and I'm lost. Can't I unplug the usb cable from the arduino and upload code from the computer through the (usb explorer + xbee) and then wirelessly to the (arduino + xbee + shield + power source)? I can view the terminal recieving the serial commands but this is it.
I’m not dead certain of this, but I don’t think that you can expect to program an Arduino through the XBee shield. I don’t remember seeing anything that would lead one to expect that to work.
The only issue is generating the reset for the uC (which
will start the bootloader).
One way I have done this is to use a software reset (which requires
a bootloader modification). See http://tinyurl.com/yzfe74b
Another way is to use a hardware line from the XBee or an external
one-shot to reset the uC. The important thing is to hold the reset
line low long enough to guarantee a reset.
