Hello guys,
We already asked that question on stackoverflow but no answer. I hope you will find !
We are developping an app that uses Bluetooth library to communicate with an Arduino in bluetooth via an HC-05 module. We made a dummy configuration to test the delay without any computation from eather the Arduino or the app and we have a huge delay of about 1 second between a request and an answer...
Protocol looks easy : Android send byte -2 and if byte received is -2, Arduino send -6, -9 and Android answer again and again.
Android Code :
h = new Handler() {
public void handleMessage(android.os.Message msg) {
switch (msg.what) {
case RECIEVE_MESSAGE: // if receive massage
byte[] readBuf = (byte[]) msg.obj;
for(int i=0;i < readBuf.length;i++)
if((int) readBuf[i] != 0) {
txtArduino.append(String.valueOf((int) readBuf[i]) + ", ");
byte[] msg = {-2};
mConnectedThread.writeByte(msg);
Arduino Code :
const int receveidBuffLen = 8*4;
if (Serial.available() > 0)
byte buff[receveidBuffLen];
Serial.readBytes(buff, receveidBuffLen);
for(int i=0; i < receveidBuffLen;i++)
if(buff[i] == (byte) -2) // 254
byte message[2] = {(byte) -6, (byte) -9};
Serial.write(message, 2);
Serial.flush();
delay(3);
Does anyone know where the delay comes from?
We changed the HC05 baudrate (from 9600 to 115 200) : nothing happened. We changed HC05 with another : nothing happened. We used the Blue2Serial library (Bluetooth as SPP) before and delay was the same... We used another controler (ESP8266) and delay still was 1 second...
Thanks in advance !
