Arduino Android Servo
Hello is possible change this compilation for a servo? i dont have a step motor
Please i need your help!
Thank you very much.
#include <LiquidCrystal.h>
#include <Stepper.h>
#define STEPS 2048 //Number of steps per revolution
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
Stepper small_stepper(STEPS, 1, 3, 2, 12);
int lcd_key = 0;
int adc_key_in = 0;
int endStep = 1;
int startPos = 6600;
int endPos = 3300;
int minutes = 5;
long runtime = 0;
int rightLock = 0;
int leftLock = 13600;
int span = 0;
int stepDelay = 0;
int spanRemain = 0;
int motorPWR = 13;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
int read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
// For V1.1 us this threshold
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 250) return btnUP;
if (adc_key_in < 450) return btnDOWN;
if (adc_key_in < 650) return btnLEFT;
if (adc_key_in < 850) return btnSELECT;
// For V1.0 comment the other threshold and use the one below:
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 555) return btnLEFT;
if (adc_key_in < 790) return btnSELECT;
return btnNONE; // when all others fail, return this…
void setup(){
lcd.begin (16,2);
pinMode(motorPWR, OUTPUT);
void loop(){
digitalWrite(motorPWR, HIGH);
lcd.setCursor(0,0);
lcd.print("Start angle L/R ");
lcd.setCursor(0,1);
lcd.print(“Sel to confirm”);
small_stepper.setSpeed(9);
while(endStep){
lcd_key = read_LCD_buttons(); // read the buttons
switch (lcd_key) // depending on which button was pushed, we perform an action
case btnRIGHT:
if (startPos > rightLock){
small_stepper.step(-165);
startPos = startPos - 165;
lcd.setCursor(0,1);
lcd.print("pos: ");
lcd.setCursor(5,1);
lcd.print(startPos);
delay(250);
case btnLEFT:
if (startPos < leftLock){
small_stepper.step(+165);
startPos = startPos + 165;
lcd.setCursor(0,1);
lcd.print("pos: ");
lcd.setCursor(5,1);
delay(250);
case btnSELECT:
endStep = 0;
delay(250);
case btnNONE:
endStep = 1;
lcd.setCursor(0,0);
lcd.print("End angle L/R ");
lcd.setCursor(0,1);
endPos = startPos;
while(endStep){
case btnRIGHT:
if (endPos > rightLock){
endPos = endPos - 165;
lcd.setCursor(0,1);
lcd.print("pos: ");
lcd.setCursor(5,1);
lcd.print(endPos);
delay(250);
case btnLEFT:
if (endPos < leftLock){
endPos = endPos + 165;
lcd.setCursor(0,1);
lcd.print("pos: ");
lcd.setCursor(5,1);
lcd.print(endPos);
delay(250);
case btnSELECT:
endStep = 0;
delay(250);
case btnNONE:
endStep = 1;
lcd.setCursor(0,0);
lcd.print(“Run time: L/R “);
lcd.setCursor(0,1);
lcd.print(” “);
while(endStep){
lcd.setCursor(0,1);
lcd.print(” minutes”);
lcd.setCursor(0,1);
lcd.print(minutes);
delay(50);
case btnRIGHT:
if (minutes < 30) {
minutes = minutes + 5;
else if (minutes < 120) {
minutes = minutes + 15;
else if (minutes < 480) {
minutes = minutes + 30;
delay(250);
case btnLEFT:
if (minutes > 0 && minutes < 35) {
minutes = minutes - 5;
else if (minutes > 0 && minutes < 150) {
minutes = minutes - 15;
else if (minutes > 0 && minutes < 485) {
minutes = minutes - 30;
delay(250);
case btnSELECT:
endStep = 0;
delay(250);
case btnNONE:
runtime = (minutes * 60000);
lcd.setCursor(0,0);
lcd.print(“Program Running”);
lcd.setCursor(0,1);
lcd.print(" Minutes Left");
if (startPos > endPos){
span = startPos - endPos;
spanRemain = span;
stepDelay = (runtime / span);
small_stepper.step(span);
while (spanRemain) {
small_stepper.step(-1);
runtime = (runtime - stepDelay);
lcd.setCursor(0,1);
lcd.print((runtime / 60000) + 1);
spanRemain–;
delay(stepDelay);
span = endPos - startPos;
spanRemain = span;
small_stepper.step(span * -1);
small_stepper.step(1);
lcd.setCursor(0,1);
spanRemain–;
delay(stepDelay);
endStep = 0;
while(1){
lcd.setCursor(0,0);
lcd.print(" “);
lcd.setCursor(0,1);
lcd.print(“Program Complete”);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(” ");
Yes, it is.
