What made you consider installing the AVRSTL library? From what I can tell this adds a number of C++ style functions, but I don't think that is the issue here. I also checked the ArduinoECCX08 Github and I don't see any mention of AVTSTL as a dependency either in the readme or the code.
1.8.9? I think perhaps that is a typo. I checked my installation of IDE 2.3.2 and see 1.8.6 and no update. I also checked the library Github page just to confirm and the latest version does appear to be 1.8.6. In fact, if I had looked closer at your previous post I would have seen the clue in your output
C:\Users\Aiuk\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:66:13:
I did a bit more research and an examination of TwoWire.h (as referenced and used by ArduinoECCX08) actually shows 5 overloads for the .requestFrom() function:
65 uint8_t requestFrom(uint8_t, uint8_t);
66 uint8_t requestFrom(uint8_t, uint8_t, uint8_t);
67 uint8_t requestFrom(uint8_t, uint8_t, uint32_t, uint8_t, uint8_t);
68 uint8_t requestFrom(int, int);
69 uint8_t requestFrom(int, int, int);
Looking at that line 912 in ECCX08.cpp, it reads as follows:
while (_wire->requestFrom((uint8_t)_address, (size_t)responseSize, (bool)true) != responseSize && retries--);
As we already said, it doesn't match any of those. The overload to most closely match this (three unsigned parameters) would be the one in line 66. The actual function definition in the corresponding .cpp file looks like this:
uint8_t TwoWire::requestFrom(uint8_t address, uint8_t quantity)
return requestFrom((uint8_t)address, (uint8_t)quantity, (uint8_t)true);
The two parameter version is actually very similar:
You see the return is actually the same. Given that the ECCx08, e.g. ECC608 chip returns either a 256 or 512 bit (32 or 64 byte) result, then it should be safe, as a temporary workaround, to rewrite line 912 as follows:
while (_wire->requestFrom((uint8_t)_address, (uint8_t)responseSize, (uint8_t)true) != responseSize && retries--);
Or even slightly shorter by dropping the third parameter:
while (_wire->requestFrom((uint8_t)_address, (uint8_t)responseSize) != responseSize && retries--);
Your output shows the path to the ECCX08.cpp file.
Initially I thought it might be worth re-installing the AVR Boards library, but from your output it is evident that you have the same version as on the Github and as I have in my installation. So I think this situation is rather odd. Perhaps Wire.h has changed since the ArduinoECCX08 was released? The ArduinoECCX08 library does seem to be being maintained and was updated only two months ago. Although it does not mention support for any of the boards based on the 32u4 chip, such as the Yun, this same AVR Boards library is used by the other Arduino boards that are supported.
I therefore think it might also be worth contacting the author via their Github repository and logging this as an issue:
https://github.com/arduino-libraries/ArduinoECCX08/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
They should at least be able confirm whether their library should work with 32u4 based boards. If the above works then you at least have temporary solution and hopefully the author will work on and provide a more permanent solution.
Sorry my post is a bit long-winded.
