Hello,
As you understand from the subject I am trying to built an aquarium controller, I am working on this project about 2 years starting from scratch because I didn't have any idea about electronics I am just a sailor... and everything I have done is with a lot of research and work, but i am in a dead end now and i would like your help!!!
My controller has an LCD (20x4), a DS1307 as RTC and 3 DS18S20, one is waterproof, for measuring the temperature I am planning to add an 8 channel relay to control multiple devices and some push buttons.
My problem is that the temperature is not very accurate i have a 0,5 degrees difference from my Temperature Controller (Elliwell ic915)and I am wondering if it is a way to calibrate the DS18S20.
And also I can't make my relay to open and close due to the temperature difference.
Here is my code if anyone can help me... (be gentle with me I am very amateur as you will understand :-[ :-[ :-[ )
#include <LiquidCrystal.h>
#include <math.h>
#include "RTClib.h"
#include <Time.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
DeviceAddress WaterTemperature = { 0x28, 0x62, 0x30, 0xCA, 0x03, 0x00, 0x00, 0xF1 };
DeviceAddress DeviceTemperature = { 0x10, 0x9A, 0x3E, 0x84, 0x02, 0x08, 0x00, 0x4D };
DeviceAddress RoomTemperature = { 0x10, 0xA1, 0xFE, 0x83, 0x02, 0x08, 0x00, 0xFC };
LCD Connections:
rs (LCD pin 4) to Arduino pin 12
rw (LCD pin 5) to Arduino pin 11
enable (LCD pin 6) to Arduino pin 10
LCD pin 15 to Arduino pin 13
LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 4, 5, 6, 7);
RTC_DS1307 RTC;
long previousLCDMillis = 0; // for LCD screen update
long lcdInterval = 20000;
// screen to show
int screen = 0;
int screenMax = 2;
bool screenChanged = true; // initially we have a new screen, by definition
// defines of the screens to show
#define SCREEN1 0
#define SCREEN2 1
#define SCREEN3 2
int ledPinFilter1 = 26; // LED connected to digital pin 28 (Filter 1)
int ledPinFilter2 = 27; // LED connected to digital pin 31 (Filter 2)
int ledPinHeater = 29; // LED connected to digital pin 27 (Heater)
int ledPinFan = 28;
int RelayPinHeater = 24;
int RelayPinFan = 25;
void setup(void)
pinMode(ledPinFilter1, OUTPUT); // sets the digital pin as output
pinMode(ledPinFilter2, OUTPUT);
pinMode(ledPinHeater, OUTPUT);
pinMode(ledPinFan, OUTPUT);
pinMode(RelayPinHeater, OUTPUT);
pinMode(RelayPinFan, OUTPUT);
digitalWrite(RelayPinHeater, LOW); // Set the Heater to LOW (off)
// Start up the library
sensors.begin();
// set the resolution to 10 bit (good enough?)
sensors.setResolution(WaterTemperature, 12);
sensors.setResolution(RoomTemperature, 11);
sensors.setResolution(DeviceTemperature, 11);
Wire.begin();
RTC.begin();
lcd.begin(20, 4);
pinMode(8,OUTPUT);
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(__DATE__, __TIME__));
lcd.begin(20, 4); // rows, columns. use 16,2 for a 16x2 LCD, etc.
showWelcome();
delay(4000); // to show message on screen}
void showWelcome()
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("My Amazon Aquarium");
lcd.setCursor(3, 1);
lcd.print("initialising...");
lcd.setCursor(1, 2);
lcd.print("Aquarium Controler");
void showScreen1()
lcd.clear();
lcd.setCursor(1, 0);// set the cursor to column 1, line 0 (first row)
lcd.setCursor(0, 1);
lcd.print("Water Temp:");
printTemperature(WaterTemperature);
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0, 2);
lcd.print("PH: 6.8");
lcd.setCursor(0, 3);
lcd.print("TDS: 150");
lcd.setCursor(9, 3);
lcd.print("ms");
void showScreen2()
lcd.clear();
DateTime now = RTC.now();
lcd.print(now.day(), DEC);
lcd.print('/');
lcd.print(now.month(), DEC);
lcd.print('/');
lcd.print(now.year(), DEC);
lcd.setCursor(12, 1);
if (now.hour()<10)
lcd.print('0');
lcd.print(now.hour(), DEC);
lcd.print(':');
if (now.minute()<10)
lcd.print('0');
lcd.print(now.minute(), DEC);
lcd.print(':');
if (now.second()<10)
lcd.print('0');
lcd.print(now.second(), DEC);
lcd.print("Room Temp:");
printTemperature(RoomTemperature);
lcd.print("C");
lcd.setCursor(8, 3);
lcd.setCursor(16, 3);
lcd.print("ms");
void showScreen3()
lcd.clear();
lcd.setCursor(6, 1);
if (now.hour()<10)
lcd.print('0');
lcd.print(':');
lcd.print('0');
lcd.print(':');
lcd.print('0');
lcd.print("C");
lcd.print("Device Temp:");
printTemperature(DeviceTemperature);
lcd.print("C");
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
lcd.print("Error");
lcd.print(tempC, 1);
void loop(void) {
unsigned long currentLCDMillis = millis();
// MUST WE SWITCH SCREEN?
if(currentLCDMillis - previousLCDMillis > lcdInterval) // save the last time you changed the display
previousLCDMillis = currentLCDMillis;
screen++;
if (screen > screenMax) screen = 0; // all screens done? => start over
// debug Serial.println(screen);
// DISPLAY CURRENT SCREEN
screenChanged = false; // reset for next iteration
switch(screen)
case SCREEN1:
showScreen1();
case SCREEN2:
showScreen2();
case SCREEN3:
showScreen3();
default:
// cannot happen -> showError() ?
const int TurnHeaterOnTemperature = 27.8; // The Temperature that sets the Heater on
const int TurnHeaterOffTemperature = 28.0; // The Temperature that sets the Heater off
const int TurnFanOnTemperature = 27.2; // The Temperature that sets the Fan on
const int TurnFanOffTemperature = 27.0; // The Temperature that sets the Fan off
sensors.requestTemperatures();
if('WaterTemperature' <= 'TurnHeaterOnTemperature'){
digitalWrite(RelayPinHeater,HIGH); // sets the Heater on
