(surfaceRT - have Tegra 3 ARM processor)
1320 / 10000
АНГЛИЙСКИЙ
Translated text thanks to Yandex translator. I have a raspberry pi 2 with a screen and windows 10 iot installed on it, as well as an application - "Automatization" - built on the basis of the "Windows Remote Arduino Experience" application.
the raspberry pi 2 has some drawbacks, for example-not the best protection against interference, problematic switching on and lack of built-in battery power time. I bought a Surface RT, hacked the bootloader, and installed Windows RT 10 Enterprise Insider Preview. There was no limit to the joy. I installed these UWP apps on it, but unfortunately I found that there are no com port emulation drivers on it. The raspberry Pi has its own Arduino Board driver - so you don't need to install an official driver to use the arduino. I had to rewrite the "automation" app a little bit so that I could see the coveted fee in the app. The corresponding item is available in the settings. I would like to make a driver for SurfaceRT or make a ported driver from Windows10IOT work. All I've managed to do so far is rewrite the inf files a bit so that the system can see the drivers, but I can't install them. I ask for help from the developers, and also offer my help in explaining all the stages. I am not an expert in any field here. I'm an electronics specialist
Переведенный текст благодаря яндекс переводчик. у меня есть raspberry pi 2 с экраном и установленным на него windows 10 iot а также приложением - "Автоматизация" - построенным на базе приложения "Windows Remote Arduino Experience". у raspberry pi 2 есть некоторые недостатки, например - не лучшая защита от помех, проблемным включением и отсутствием встроенной батареи питания времени. мною был куплен Surface RT, взломан загрузчик и установлена Windows RT 10 Enterprise Insider Preview. Радости не было предела. я установил на него эти UWP приложения, но к сожалению обнаружил, что на нем нету драйверов эмуляции com порта. На raspberry Pi есть свой драйвер платы arduino - поэтому оффициальный драйвер устанавливать не нужно для использования arduino. Пришлось чуть-чуть переписать приложение "Автоматизация" чтобы можно было увидеть в приложении заветную плату. Соответствующий пункт есть в настройках. Хотелось бы сделать драйвер для SurfaceRT или заставить работать портированный драйвер из Windows10IOT. Все что пока у меня получилось сделать - это немного переписать файлы inf чтобы система увидела драйвера, но установить у меня их не получается. Прошу помощи у разработчиков, А также предлагаю свою помощь в объяснении всех этапов. Я не являюсь специалистом ни в одной области здесь. Я специалист электроники.
