Arduino array how values are stored, how this think is working
ok is clear enought i got it.
i have one more small problem.
case 0xB it pass the information to the vumeter function,
void vumeter(byte channel, byte number, byte value) {
me i want to make a second function
like this
void vumeter_mainAmplifire(byte channel, byte number, byte value) {
and i will add a button. in voice loop so i can chose witch function to call.
hot to replace the xxxxx for this function please.
  currentState = digitalRead(vu_switch);
  if (currentState != previousState & currentState == LOW)
    state = !state;
  if (state == 0) {
    xxxxxxxxxxxxxxxxxxx  (vumeter);
    xxxxxxxxxxxxxxxxxxxx   (vumeter_mainAmplifire);
  previousState = currentState;
  midiEventPacket_t rx = MidiUSB.read();
  switch (rx.header) {
    case 0xB:
      vumeter(
        rx.byte1 & 0xF,  //channel
        rx.byte2,        //cc
        rx.byte3         //value
  int value_ = value;
  if (value_ != ccLastValue) {
    if (channel == VU_MIDI_CH) {
      if (number == 12 ) {
        switch (value_) {
          //led in row 2 are light acording to the case
          case 0:
consider this simple example that uses multiple arrays
const byte AnalogPins [] = { A1, A2, A3 };
#define Nanalog     sizeof(AnalogPins)
int potVals [Nanalog];
void loop ()
    for (unsigned n = 0; n < Nanalog; n++)  {
        potVals [n] = analogRead (AnalogPins [n]);
        Serial.print (" ");
        Serial.print (potVals [n]);
    Serial.println ();
    delay (1000);
void setup ()
    Serial.begin (9600);
