Arduino as a 1-Wire device
using the library OneWire
You can work with devices with interface 1-Wire.
But is it possible to make the Arduino to simulate the work of 1-Wire devices?
For example, I connected to the Arduino iButton DS1990A
and read the number:
include <OneWire.h>
  • Test work on the 1-Wire from iButton DS1990A
OneWire ds(10); // [ch1085][ch1072] digital pin 10
void setup(void) {
void loop(void) {
byte i;
byte present = 0;
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
Serial.print("No more addresses.\n");
ds.reset_search();
return;
Serial.print("R=");
for( i = 0; i < 8; i++) {
Serial.print(addr*, HEX);*
  • Serial.print(" ");*
  • if ( OneWire::crc8( addr, 7) != addr[7]) {*
  • Serial.print("CRC is not valid!\n");*
  • return;*
  • if ( addr[0] != 0x01) {*
  • Serial.print("Device is not a DS1990A family device.\n");*
  • return;*
  • Serial.println();*
  • ds.reset();*
  • delay(1000);*
    [/quote]
    So can we now make the Arduino to identify itself as such a key?
    I.e. Arduino connected to a door and open the door? :slight_smile:
