The resonators used on the cheap boards isn't very accurate.
Replace it with a crystal, or get a real-time clock, or get a GPS module with a 1 pulse-per-second output, and count pulses.
JZKSK:
Very simple program, using delay(), but it's not working. Time is not exact.
Yes, of course it's not very exact.
Which Arduino board do you use?
Accuracy of internal Arduino board timing g depends directly on accuracy of controller clocking.
So if you have a 16 MHz board which is clocked by a ceramic resonator, your timing done by "delay()" or "millis()" functions may be inaccurate up to 0.8%, which means:
runtime of delay(1000); might be something between 992 and 1008 milliseconds, actually.
delay(2000) might be in the range 1984 ... 2016 milliseconds actually
and delay(58000) might be in the range 57536 ... 58464 milliseconds actually
(with 16 MHz AVR Atmega boards in R3 design like "UNO R3" or "MEGA2560 R3"
BTW: Switching time of mechanical relays may vary, too.
Relay switching time from OFF to ON might differ from switching time ON to OFF
You can achieve much better accuracy on the long run by
using an Arduino board which creates system clocking from a crystal oscillator instead ceramic resonator
or by using a RTC with square wave output enabled and simply counting pulses from the SQW output of the RTC module
get a DS3231 or DS3232 they are now the same price as the older 1307 modules but much more accurate.
They also have a temperature sensor if you want or need temperature readings.
Another option is to calibrate the timing functions such as millis().
I dont think i would recommend this method with a ceramic resonator, but with a crystal yes, as long as you can get the results you need of course and you did not state the tolerance you are after so i dont know that info yet.
The idea is very simple but it does take some time and effort to get it right because you are basically calibrating something that needs to be checked over minutes or even hours to get the right tolerance, and the program may vary slightly depending on the accuracy requirement.
The calibration code simply adds or subtracts one, two, or more milliseconds to the millis() function once for every so many millis(), in order to make a count over say an hour very close to an actual hour which is 3600000 milliseconds. If the clock is slow you add milliseconds, and if the clock is fast you subtract milliseconds. The amount you add or subtract comes first from your testing where you compare the count at the end of one full (and exact) hour as measured by a trusted timepiece. Once you get it set, it should work for as long as the board stays at that same temperature. This also means that it only works in an environment that stays at about the same temperature, unless of course you want to add temperature compensation.
Of course it takes some time to get this right, so it is not for someone in a hurry.
The best solution though for a reasonable price is the RTC module as others here have pointed out. The one with the internal crystal though, not the one with the external crystal as that is less accurate and can drift more.
Good luck with it whatever you decided to do. Sounds like you want to go with the RTC so far though which i think is a good choice.
