Arduino as an AVR ISP
Hi there!
I´ve read the tutorial explaining how to use an Arduino board to burn the bootloader onto an AVR using the Arduino IDE. I´ve also read that it is based on the mega-isp code written by someone else and had a look at it too.
So, is it possilbe to use that same sketch and AVRdude to directly program any supported microcontroller? Should I make any changes?
Any tip or help is most welcomed!
Thanks.
yep
Thanks for the straightforward answer!
As far as I´ve read it also supports burning fuses, lock bits, etc...
Would this be OK?
avrdude -p m328p -P comX -c avrisp -b 19200 -U flash:w:file.hex -U lock:w:0xFF:m
m328p : ATmega328p micro
comX: my com port
file.hex: my program
-U lock:w:0xFF:m -> for the lock bits ( all unprogrammed )
Thanks!
should be fine as long as you have your fuses correct, but yea thats pretty much it for avrdude
I would recommend that you add two (-v -v) verbose output specifiers to the avrdude command line, at least while testing. It adds very useful output that can help diagnose problems.
Luciano_Carcagno:
Would this be OK?
Almost...
avrdude -p m328p -P comX -c stk500 -b 19200 -U flash:w:file.hex -U lock:w:0xFF:m
  • OR -
avrdude -p m328p -P comX -c arduino -b 19200 -U flash:w:file.hex -U lock:w:0xFF:m
wanderson:
Thanks! I´ll take a look at that.
I got a bit confused with this. I thought that the idea of using an Arduino board with the ArduinoISP example was to work as AVRISP. :~
I use avrisp as the programming option all the time, works for me, including in your core files CB
Luciano_Carcagno:
...a programmer. "AVRISP" is a specific kind of programmer. It is also a protocol. The -c option tells avrdude which protocol to use. For an Arduino running the ArduinoISP sketch, the correct protocol is stk500 or arduino.
Osgeld:
I've had problems using avrisp as the protocol. Unfortunately, I can't remember the details.
The best advice: Whatever works is the correct option. :wink:
Agreed, cause STK500 is just an error generator for me, have yet to get it to do anything though an arduino as an ISP, I dont remember what arduino did, its been awhile.
Great advice! Thanks for all the tips.
