Hi all,
I'm a complete noob in arduino (did do some basic things in it). Now I'm working on a thesis project where I want to measure some things (Thrust, torque, temperature, pressure, rpm, V and I from an electric motor). Is it possible to measure those things multiple times with arduino, or should i need something like labview and professional equipement like boards of national instruments?
Basically what i want to do is vary the rpm from let's say 5000-15000 and while doing that save the values of
- a load cell (have found a tuturial for that, thanks)
- Torque transducer (this might be more tricky, as all the thesises i found are done by using national instruments and labview)
- rpm (I have an rpm meter with display, but associating the data with the measured values of the other variables would be very handy i guess)
- V and I drawn by the electric motor (this is just measured by a multimeter, but again, if this could be done by arduino, it would be much better).
Before I want to jump into reading I want to know if it's possible to make. I'm a uni student and have some time to learn to work with arduino, as i don't have any courses anymore, just this. But before doing and buying things I want to know if it's possible or not. I guess the values would need to be measured and saved multiple times a second.
Thanks for having a look at this topic, and I hope I can learn from all of you.
