Arduino as ISP signature problem?
Hi all,
I'm currently in the middle of a project in which I've made a pcb equipped with a Atmega328-AU. Unfortunattely I'm not able to burn a bootloader on my chip, I'm using an arduino UNO to do so. The error message I get is: "avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check."
Though, I checked my connections multiple times. I guess it has to do with the signature bytes of the 328-au?
Any suggestions on how to solve this are welcome!
Niels
What device name did you use?
Could it be the difference between the P and non-P error, described here
http://arduino.cc/forum/index.php/topic,98956.0.html
Erni: Could it be the difference between the P and non-P error, described here
Thanks man, that solved it!
Niels,
