Arduino as Lego Mindstorms NXT RC Sensor
I've recently been messing around with a radio control to Lego Power Functions IR converter. This works well for the Power Functions IR sensor, but to use it with a NXT Mindstorms you need a HiTechnic IR Receiver sensor, and even then its double handling.
So I turned the Arduino into a sensor that communicates to the NXT with I2C. The code mimics the HiTechnic sensor, so the same NXT-G brick can be used, as well as the same NXC code.
Essentially it decodes the PPM signal from the RC receiver and then converts it to the standard Lego speed values. The module itself is very useful as it allows you to have 8 sensors (4 channels, 2 motors per channel) with values from 0 - 100 as well as logic, so you could turn it into whatever sensor you want.
// Intended to allow an Arduino to mimic a Hitech IRRceiver for Radio Control
// http://www.hitechnic.com/cgi-bin/commerce.cgi?preadd=action&key=NIR1032
// Edit the ServoDecode.h and set MAX_CHANNELS to correct number. Otherwise the transmitter must be turned on before receiver.
// ServoDecode Library @ http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1228137503/0
// RC PPM input on pin 8
// NXT Connector pinout http://en.wikipedia.org/wiki/Lego_Mindstorms_NXT#Connector
// Arduino ground -> NXT pin 2 and 3
// Arduino 5V -> NXT cable pin 4
// Arduino pin A4 -> NXT cable pin 6
// Arduino pin A5 -> NXT cable pin 5
#include <Wire.h>
#include <ServoDecode.h>
//  Address for the Arduino to announce itself as
#define ID 0x01
#define ADDRESS ID
#define ADDRESS_SEND 2
#define ADDRESS_RECV (ADDRESS_SEND - 1)
// Original information
// uint8_t SensorVersion[9] = " V1.1   ";
// uint8_t SensorName[9] =    "HiTechnc";
// uint8_t SensorType[9] =    "IRRecv  ";
uint8_t SensorVersion[9] = " V0.1   ";
uint8_t SensorName[9] =    "Arduino ";
uint8_t SensorType[9] =    "RadioCon";
byte x;
byte buffer[9] = {
  0,0,0,0,0,0,0,0};
byte sendbuffer[] = {
  0, 0};
//  Lego Power Functions IR values.  -128 is Break.
int PWM_MODE[] = {
  0, 16, 30, 44, 58, 72, 86, 100, -128};
// RC receiver channels to sample
int PanChan = 1;
int ThrustChan = 2;
int TiltChan = 3;
int SteerChan = 4;
int SwitchChan = 5;
int PPM_Min = 990;
float Tolerance = 0.05;
//unsigned long InitialPan;
unsigned long InitialThrust;
//unsigned long InitialTilt;
unsigned long InitialSteer;
//unsigned long InitialSwitch;
unsigned long Steer;
unsigned long Thrust;
unsigned long Pan;
unsigned long Tilt;
unsigned long Switch;
unsigned long S;
unsigned long T;
unsigned long Left;
unsigned long Right;
//Steering and Thrust High and Low Tolerances, used for channel mixing.
int S_H_Tol;
int T_H_Tol;
int S_L_Tol;
int T_L_Tol;
//  If the Failed samples count is greater than 10 then disable.  If the Ready count is greater than 1000 then enable.
int Fail_count = 0;
int Ready_count = 0;
  Serial.begin(57600);
  pinMode(8, INPUT); // RC input
  Wire.begin(ID);
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent);
  ServoDecode.begin();
  ServoDecode.setFailsafe(1,1500);
  ServoDecode.setFailsafe(2,1500);
  ServoDecode.setFailsafe(3,1500);
  ServoDecode.setFailsafe(4,1500);
  ServoDecode.setFailsafe(5,1500);
void loop(){
  if (ServoDecode.getState()!= READY_state) {
    ++Fail_count;
    Fail_count = constrain(Fail_count, 0, 10);
    if (Fail_count == 10){
      Ready_count = 0;
      InitialThrust = 1500;
      InitialSteer = 1500;
      digitalWrite(13,LOW); // Turn LED off
  else{
    ++Ready_count;
    Ready_count = constrain(Ready_count, 0, 1000);
    if (Ready_count == 1000){
      Fail_count = 0;
      digitalWrite(13,HIGH); // Light an LED When Ready
//  Ready count to try to prevent any false activation
  if (Ready_count == 999){
    InitialThrust = ServoDecode.GetChannelPulseWidth(ThrustChan) - PPM_Min;
    InitialSteer = ServoDecode.GetChannelPulseWidth(SteerChan) - PPM_Min;
  if ( Ready_count == 1000) {
    Steer = constrain((ServoDecode.GetChannelPulseWidth(SteerChan) - PPM_Min), 0, 1000);
    Thrust = constrain((ServoDecode.GetChannelPulseWidth(ThrustChan) - PPM_Min), 0, 1000);
    Pan = constrain((ServoDecode.GetChannelPulseWidth(PanChan) - PPM_Min), 0, 1000);
    Tilt = constrain((ServoDecode.GetChannelPulseWidth(TiltChan) - PPM_Min), 0, 1000);
    Switch = constrain((ServoDecode.GetChannelPulseWidth(SwitchChan) - PPM_Min), 0, 1000);
    // invert stick if needed
    Tilt = 1000 - Tilt;
    //-------------------------------------Channel Mixing------------------------------------------//
    S_H_Tol = InitialSteer + InitialSteer * Tolerance;
    S_L_Tol = InitialSteer - InitialSteer * Tolerance;
    T_H_Tol = InitialThrust + InitialThrust * Tolerance;
    T_L_Tol = InitialThrust - InitialThrust * Tolerance;
    S = Steer;
    T = Thrust;
    // Mix Steer and Thrust into Left and Right
    // Forward Right
    if ((T > T_H_Tol) && (S > S_H_Tol)){
      Right = T - (S - InitialSteer);
      Left = T;
    //Forward Left
    if (( T > T_H_Tol) && (S < S_L_Tol) ){
      Right = T;
      Left = T - (InitialSteer - S);
    //Back Right
    if (( T < T_L_Tol) && (S > S_H_Tol) ){
      Right = T - (InitialSteer - S);
      Left = T;
    //Back Left
    if (( T < T_L_Tol) && (S < S_L_Tol) ){
      Right = T;
      Left = T - (S - InitialSteer);
    // Turn on spot
    if (T <= T_H_Tol && T >= T_L_Tol){
      Right = 2 * InitialSteer - S;
      Left = S;
    //Forward and Back
    if (S <= S_H_Tol && S >= S_L_Tol){
      Right = T;
      Left = T;
    if (Left <= T_H_Tol && Left >= T_L_Tol && Right <= T_H_Tol && Right >= T_L_Tol) {
      Left = InitialThrust;
      Right = InitialThrust;
    Left =   constrain(Left, 0, 1000);
    Right =  constrain(Right, 0, 1000);
//    PWM_trans(Steer, 0);
//    PWM_trans(Thrust, 1);
    PWM_trans(Left, 0);
    PWM_trans(Right, 1);
    PWM_trans(Pan, 2);
    PWM_trans(Tilt, 3);
    PWM_trans(Switch, 4);
void PWM_trans(int val, int out){
  if ( val > 940){  //7 FWD
    buffer[out] = PWM_MODE[7];
  else if (val >= 880 && val <= 940){ // 6 FWD
    buffer[out] = PWM_MODE[6];
  else if (val >= 820 && val <= 880){ // 5 FWD
    buffer[out] = PWM_MODE[5];
  else if (val >= 760 && val <= 820){ // 4 FWD
    buffer[out] = PWM_MODE[4];
  else if (val >= 700 && val <= 760){ // 3 FWD
    buffer[out] = PWM_MODE[3];
  else if (val >= 640 && val <= 700){ // 2 FWD
    buffer[out] = PWM_MODE[2];
  else if (val >= 580 && val <= 640){ // 1 FWD
    buffer[out] = PWM_MODE[1];
  else if (val >= 420 && val <= 580){ // FLT
    buffer[out] = PWM_MODE[0];
  else if (val >= 360 && val <= 420){ // 1 REV
    buffer[out] = 0 - PWM_MODE[1];
  else if (val >= 300 && val <= 360){ // 2 REV
    buffer[out] = 0 - PWM_MODE[2];
  else if (val >= 240 && val <= 300){ // 3 REV
    buffer[out] = 0 - PWM_MODE[3];
  else if (val >= 180 && val <= 240){ // 4 REV
    buffer[out] = 0 - PWM_MODE[4];
  else if (val >= 120 && val <= 180){ // 5 REV
    buffer[out] = 0 - PWM_MODE[5];
  else if (val >= 60 && val <= 120){ // 6 REV
    buffer[out] = 0 - PWM_MODE[6];
  else if (val < 60){// 7 REV
    buffer[out] = 0 - PWM_MODE[7];
//---------------------------------I2C Events-------------------------------//
void receiveEvent(int howMany){
  x = Wire.receive(); // receive byte as an integer
void requestEvent(){
  if (x == 0x00){
    Wire.send(SensorVersion, 8);
  else if (x == 0x08){
    Wire.send(SensorName, 8);
  else if (x == 0x10){
    Wire.send(SensorType, 8);
  else if (x == 0x42){// Channel 1, Motor 1A and 1B
    sendbuffer[0] = buffer[0];
    sendbuffer[1] = buffer[1];
    Wire.send(sendbuffer, 2);
  else if (x == 0x44){// Channel 2, Motor 2A and 2B
    sendbuffer[0] = buffer[2];
    sendbuffer[1] = buffer[3];
  else if (x == 0x46){// Channel 3, Motor 3A and 3B
    sendbuffer[0] = buffer[4];
    sendbuffer[1] = buffer[5];
  else if (x == 0x48){// Channel 4, Motor 4A and 4B
    sendbuffer[0] = buffer[6];
    sendbuffer[1] = buffer[7];
The code itself is probably a little rough still but works well.
The RC receiver as well as the arduino can both be powered from the NXT 4.3V line. However the 3.3V/8MHz Arduino Pro Mini doesn't have the processor power to be able to handle the servo decoding, so you have to use the 5V/16MHz version (I tested this on the RC-IR converter), this still works fine powered from the NXT. In testing I was using a Duemilanove and had no power issues.
4.3 volts should be fine for 16MHz operation
You can simplify the PPM translation using something along these lines :
int index = val / 60;
  if(index > 7)
    buffer[out] = PWM_MODE[index -7];
    buffer[out] = -PWM_MODE[7-index] ;
Nice, I was looking at the possibilities of using NXT and arduino a few weeks ago becuase I have a bit of it to play with :wink:
Mowcius
Mem,
Thanks for that, I had seen that everything seemed to work ok, but its nice to have confirmation that there won't be some problems down the track.
I think this would work:
  if(index > 9){
    buffer[out] = PWM_MODE[index -9];}
  else if (index > 7){
    buffer[out] = -PWM_MODE[7-index] ;}
  else {buffer[out] = PWM_MODE[0];}
That said, both the PWM modes as well as the steps are arbitrary. The PWM modes are the Lego PWM values for the IR speed controller. The steps are just to give the stick a smooth-ish speed increase. You could just as easily translate the raw PPM values into the NXT to give a much smoother curve. I stuck with the Lego values just for compatibility reasons.
Thanks Mowcius :slight_smile:
I have seen that a few people have done work on using the arduino as a sensor before, but all those seemed to either lack documentation or require some special coding on the NXT to work. You can just use the HiTechnic NXT-G program block or the existing NXC commands for this.
I was actually surprised at how easy I2C was to get working in this, although my Bus Pirate helped track down a could of bugs :stuck_out_tongue:
Hello,
what you did looks great.
I'm also trying to do similar as what you did as practice, since I have arduino and NXT.
I'm trying to use arduino as sensor that sends 1 byte back to NXT when NXT request to arduino.
So, I tried arduino receiving byte from NXT first.
However, I realized that arduino and NXT have different clock speed.
So, I have few questions...
  1. Did you use pin 5, 6 from NXT wire, and analog pin 4, 5 from arduino(Duemilanove)?
  2. Did you need external power(I'm thking USB for testing, and when it's done planning to attach external battery pack) to arduino?
Thank You,
-HK-
