Arduino as LEGO PF receiver
There are several projects as LEGO PF transmitter with Arduino, I want to know if there is a implementation for LEGO PF Receiver with Arduino?
I found OPEN POWER FUNCTIONS RECEIVER, he used a microcontroller is an AVR attiny44A, a TSOP4136 infrared receiver, and motor driver DRV8835.
Here is circuit and print board.
Here is source, I want to know if this impossible by Arduino? and size is similar with this hack receiver?
#ifndef LEGOPFRC_H_
#define LEGOPFRC_H_
//#include <avr/io.h>
#include "stm32f0xx.h"
#define TIMEOUT_MESSAGES 1
#define OpenPfRx_CHANNEL_MASK                  0x3000
#define OpenPfRx_ESCAPE_MASK                   0x4000
#define OpenPfRx_MODE_MASK                     0x0700
#define OpenPfRx_TOGGLE_MASK                   0x8000
#define OpenPfRx_ADDRESS_MASK                  0x0800
#define OpenPfRx_SINGLEOUTPUT_CSTIDMODE_MASK   0x0200
#define OpenPfRx_SINGLEOUTPUT_DDDD_MASK        0x00F0
#define OpenPfRx_SINGLEOUTPUT_OUTPUT_MASK      0x0100
#define OpenPfRx_OUTPUTA_MASK                  0x00F0
#define OpenPfRx_OUTPUTB_MASK                  0x0F00
#define OpenPfRx_EXTENDED_MODE      0
#define OpenPfRx_COMBO_DIRECT_MODE  1
#define OpenPfRx_RESERVED_1         2
#define OpenPfRx_RESERVED_2         3
#define OpenPfRx_SINGLE_OUTPUT_MODE 4
#define OpenPfRx_DATA_MASK   0x00F0
#define OpenPfRx_MAX_PWM_VALUE 255
#define OpenPfRx_MIN_PWM_VALUE 0
#define OpenPfRx_PWM_VALUE_STEP (OpenPfRx_MAX_PWM_VALUE/8)
#define OpenPfRx_PWM_VALUE_OFFSET 10
enum OpenPfRx_RECEIVER_STATE    {IDLE, WAIT_FOR_START, WAIT_FOR_BIT,WAIT_FOR_STOP};
enum OpenPfRx_RECEIVER_IR_STATE {IR_ENABLED, IR_DISABLED};
enum OpenPfRx_IR_LENGTH_VALUES  {IR_LENGTH_INIT = 0, IR_LENGTH_LO=3, IR_LENGTH_HI=5, IR_LENGTH_START_STOP=9, IR_LENGTH_TIMEOUT = 11}; // minimum number of 105 us periods for each value
enum OpenPfRx_MODES             {EXTENDED_MODE, COMBO_DIRECT_MODE, RESERVED, SINGLE_OUTPUT_MODE, COMBO_PWM_MODE};
enum OpenPfRx_PWM_INDEX         {PWM_OFF = 0, PWM_FLOAT=0, PWM_BRAKE_THEN_FLOAT=0, PWM_STEP1, PWM_STEP2, PWM_STEP3, PWM_STEP4, PWM_STEP5, PWM_STEP6, PWM_STEP7, PWM_FULL};
enum OpenPfRx_OUTPUT_MODES      {OM_FWD,OM_BWD,OM_FLOAT,OM_BRAKE,OM_BRAKE_THEN_FLOAT,OM_INDEPENDENT};
struct OpenPfRx_receiver {
    uint8_t bit_count;
    //enum OpenPfRx_RECEIVER_STATE state;
    //enum OpenPfRx_RECEIVER_IR_STATE irstate;
    uint8_t state;
    uint8_t irstate;
    volatile uint8_t  periodcounter; //count each iteration of the timer
    volatile uint16_t rxdata;
    volatile uint8_t  newdata;
    //uint8_t  checksum_ok;
struct OpenPfRx_output
    //enum OpenPfRx_MODES mode;
    //both the index and value are stored; to increment 'numerical' PWM value the value must be available,
    //to incremente PWM step the index must be available
    uint8_t pwmvalue;
    enum OpenPfRx_PWM_INDEX pwmindex;
    enum OpenPfRx_OUTPUT_MODES output_mode;
    //uint8_t pwmindex;
    //uint8_t output_mode;
    uint16_t brakethenfloatcount;
    int8_t C1;
    int8_t C2;
struct OpenPfRx_channel
    uint16_t timeout;
    uint16_t timeout_limit;
    uint8_t  timeout_action;
    uint8_t channel_number;
    uint8_t toggle;
    struct OpenPfRx_output A;
    struct OpenPfRx_output B;
//global definition
struct OpenPfRx_receiver OpenPfRx_rx;
//function declarations
extern void OpenPfRxdebug(void);
void OpenPfRx_channel_init(struct OpenPfRx_channel*, uint8_t);
uint8_t OpenPfRxVerifyChecksum(uint16_t);
void OpenPfRxPinInterruptState(void);
//inline void OpenPfRx105usState(void);
void OpenPfRxInterpreter(const uint16_t * , struct OpenPfRx_channel *);
//uint16_tone_ms_to_timerticks(); //EXTERN function to get number of timer ticks per millisecond
void OpenPfRxComboPWMMode(const uint16_t *, struct OpenPfRx_channel *);
void OpenPfRxExtendedMode(const uint16_t *, struct OpenPfRx_channel*);
void OpenPfRxComboDirectMode(const uint16_t *, struct OpenPfRx_channel*);
void OpenPfRxSingleOutputMode(const uint16_t *, struct OpenPfRx_channel*);
uint8_t OpenPfRxVerifyToggleBit(const uint16_t *, struct OpenPfRx_channel*);
uint8_t OpenPfRxGetChannelNumber(uint16_t);
static inline void OpenPfRx105usState(void)
    if(OpenPfRx_rx.periodcounter > IR_LENGTH_TIMEOUT)
        if(OpenPfRx_rx.state == WAIT_FOR_STOP) //stop bit succesfully received; no IR during pause
            OpenPfRx_rx.newdata = 1;
        OpenPfRx_rx.state = IDLE;
    OpenPfRx_rx.periodcounter++;
