Hi
I would like to read a total of 2 analog inputs on a Due board. I have been using the following code that works well with 1 analog input. How can I modify it to read 2 analog inputs and display the outputs at the serial port.
// Arduino as load cell amplifier
// by Christian Liljedahl
// christian.liljedahl.dk
// Load cells are linear. So once you have established two data pairs, you can interpolate the rest.
// Step 1: Upload this sketch to your arduino board
// You need two loads of well know weight. In this example A = 10 kg. B = 30 kg
// Put on load A
// read the analog value showing (this is analogvalA)
// put on load B
// read the analog value B
// Enter you own analog values here
float loadA = 2.9; // kg
int analogvalA = 677; // analog reading taken with load A on the load cell
float loadB = 69.1; // kg
int analogvalB = 2955; // analog reading taken with load B on the load cell
// Upload the sketch again, and confirm, that the kilo-reading from the serial output now is correct, using your known loads
float analogValueAverage = 0;
// How often do we do readings?
int timeBetweenReadings = 200; // We want a reading every 200 ms;
analogReadResolution(12);
int analogValue = analogRead(0);
// running average - We smooth the readings a little bit
analogValueAverage = 0.99analogValueAverage + 0.01analogValue;
// Is it time to print?
float load = analogToLoad(analogValueAverage);
Serial.println(load,1);
float analogToLoad(float analogval){
// using a custom map-function, because the standard arduino map function only uses int
float load = mapfloat(analogval, analogvalA, analogvalB, loadA, loadB);
return load;
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Thank you in advance Nevjc
