Arduino as logic driver
This code is now working properly.
Outputs will change as input voltage rises 0V to 5V.
6 different situations.
  pinMode(22,OUTPUT);
  pinMode(23,OUTPUT);
  pinMode(24,OUTPUT);
  pinMode(25,OUTPUT);
  pinMode(26,OUTPUT);
  pinMode(27,OUTPUT);
  pinMode(28,OUTPUT);
  pinMode(29,OUTPUT);
  pinMode(30,OUTPUT);
  pinMode(31,OUTPUT);
  pinMode(32,OUTPUT);
  pinMode(33,OUTPUT);
  pinMode(34,OUTPUT);
  pinMode(35,OUTPUT);
  pinMode(36,OUTPUT);
  pinMode(37,OUTPUT);
  pinMode(A1, INPUT);
  int sensorValue = analogRead(A1);
  if (sensorValue <= 170.5 )
 {digitalWrite(22, LOW);
  digitalWrite(23, HIGH);
  digitalWrite(24, LOW);
  digitalWrite(25, LOW);
  digitalWrite(26, HIGH);
  digitalWrite(27, LOW);
  digitalWrite(28, LOW);
  digitalWrite(29, HIGH);
  digitalWrite(30, LOW);
  digitalWrite(31, LOW);
  digitalWrite(32, HIGH);
  digitalWrite(33, LOW);
  digitalWrite(34, LOW);
  digitalWrite(35, HIGH);
  digitalWrite(36, LOW);
  digitalWrite(37, LOW);
  if (sensorValue >= 170.6 && sensorValue < 341)
  digitalWrite(34, HIGH);
  digitalWrite(35, LOW);
  digitalWrite(36, HIGH);
  digitalWrite(37, HIGH);
  if (sensorValue >= 341.1 && sensorValue < 511.5)
  digitalWrite(31, HIGH);
  digitalWrite(32, LOW);
  digitalWrite(33, HIGH);
  if (sensorValue >= 511.6 && sensorValue < 682)
  digitalWrite(28, HIGH);
  digitalWrite(29, LOW);
  digitalWrite(30, HIGH);
  if (sensorValue >= 682.1 && sensorValue < 852.5)
  digitalWrite(25, HIGH);
  digitalWrite(26, LOW);
  digitalWrite(27, HIGH);
  if (sensorValue >= 852.6 && sensorValue < 1023)
 {digitalWrite(22, HIGH);
  digitalWrite(23, LOW);
  digitalWrite(24, HIGH);
Show your complete sketch.
Use CTRL T to format your code.
Attach your sketch between code tags
[code]Paste your sketch here[/code]
To start with, learn to use braces { }
See how to use the if/else syntax.
Where are you defining your pins?
if (sensorValue >= 852,6What's that comma doing there?
AWOL:
Im try to share analog input voltage information to 6 different case digital outputs. This is if voltage is 5/1023*852,6 amount.
Did you read:
analogRead does not return a floating point value, and anyway in C, the comma is not a decimal point
larryd:
Did you read:
if - Arduino Reference
Not yet before I made post. This might help something. Thanks
What is a logic driver?
as for giving you a clue about the error msg.digitalWrite(pin23, HIGH); pin23 has not been declared as a variable but if you want to set pin 23 HIGHdigitalWrite(23, HIGH); will suffice.
larryd:
With arduino we can replace quite amount of logic circuits and make same stuff as whole big logic circuit
You mean a Logic Gate.
Deva_Rishi:
will suffice.
Yes thank you very much, code passed check now. Thou need to test it still if it do what it should do.
larryd:
Gate is one circuit, arduino can "drive" whole circuit system
You might be thinking of a programmable device or PLA.
