I'm learning Arduino by programming in assembler, it is something new for me. I wrote my successfully first program to blink a led.
Now I'm looking at instruction set manual and I was wondering whether there is a logical instruction to negate a register or a single bit. I would like to rewrote the branchless blinking version.
Now I'm using the sbi and cbi, I'm searching for something similar but to negate a bit.
Note: The "Exclusive OR" instruction is named "EOR", not "XOR". It works on two registers: Destination,Source
Further note: The "CLR" instruction is just the EOR instruction with both registers the same.
There is a "Load and Toggle" (LAT) instruction. It fetches a byte through the pointer register 'Z', XOR's it with the named register, and stores it back through Z.
From a technical / pedantic perspective this does not make sense.
"Arduino" can refer to many things, from h/w to s/w.
Arduino does not really refer to any specific board although many often refer to AVR based boards like the UNO as simply "Arduino".
But from a s/w perspective, Arduino is about creating an easy to use environment that provides a core library (in C) that hides all the raw h/w from the user using abstraction APIs and then provides C++ libraries on top of that for additional functionality.
If you are directly accessing the h/w - which you would be when using assembler, you are stepping outside the Arduino programming environment.
When programming in assembler, using the assembler from gcc toolset is a bit messy since the gcc tools (which is what comes with the Arduino IDE) don't use the official/Atmel assembler mnemonics/language.
There are other tools like Atmel Studio (if using Windows) that, IMO, would better if wanting to program directly to the h/w in assembler.
