Hello all.
I have a classic circuit with nRF24L01 module plus Arduino IC and RF24 lib. It works ok when the Arduino is powered with 5V but seems to not receive packages (or cannot decode the data in the packages) when the Arduino is at 3V3 supply.
The packets sent goes ok, at least with up to 16 byte length packages.
The RF module is always supplied with 3V3.
Seems like the Arduino chip changes something like operation frequency or some timing in the SPI bus.
As far as I can see in the IC data sheet it should work well with 16MHz crystal from 2.7V up to 5V.
Since the transmitted packets are okay the fail to receive seems odd.
Maybe I have to configure the ATMega different to work correctly with 3V3 supply.
Perhaps someone here has seen this before and could give a hint.
Thank you
Problem solved!
A simple decoupling cap was missing in the power connection to RF module.
Found it when powering the module with separate battery.
Sorry for the jump up here.
30 years of engineering and forgot to add a simple capacitor...
